Friend needs help
Old Feb 2, 2014 | 03:12 PM
Vinford's Avatar
Vinford
Friend needs help
2003 7.3 F-350
No start..................
Changed batterys
Checked fuses
Checked oil level in HPOP
Changed IDM module
Changed injector harrnass
CPS
Still no start.
Smoke coming out exhaust when turning over.
Old Feb 2, 2014 | 03:19 PM
Pikachu's Avatar
Pikachu
Sounds like classic symptoms of a non-functioning glow plug system. Have the GPR and the glow plugs been tested?
Old Feb 2, 2014 | 04:29 PM
Vinford's Avatar
Vinford
It would still start without glowplugs wouldn't it?
Like it went from a running truck to not starting at all.
Old Feb 2, 2014 | 04:35 PM
bielaf's Avatar
bielaf
Try plugging it in over night and try starting it in the morning.How long ago was it running a couple mins, hours or just the other day
Old Feb 2, 2014 | 04:41 PM
JWC 3's Avatar
JWC 3
Any codes ?
Old Feb 2, 2014 | 04:45 PM
excavator's Avatar
excavator
if you have white smoke then it sure sounds like glow plug relay or plugs not all working. As mentioned plug it in fir few hours and if it starts that confirms it unless you have bad injector poppet valves
Old Feb 2, 2014 | 04:51 PM
Vinford's Avatar
Vinford
I told him to plug it in , we will see in a few hours its not cold where he is.
Old Feb 2, 2014 | 05:22 PM
Vinford's Avatar
Vinford
It quit while he was driving it down a gravel road.
Old Feb 2, 2014 | 05:25 PM
JWC 3's Avatar
JWC 3
Originally Posted by JWC 3
Any codes ?
any codes ?
Old Feb 2, 2014 | 05:26 PM
JWC 3's Avatar
JWC 3
scan tool help is needed
Old Feb 2, 2014 | 05:39 PM
dn29626's Avatar
dn29626
Is it getting fuel? (Open bowl drain and cycle with key.)
Old Feb 2, 2014 | 05:44 PM
Pikachu's Avatar
Pikachu
That completely changes things. If it just quit while driving, the glow plug system isn't the suspect. I'd change the CPS first if I didn't have access to a scan tool. They're about $35 at the dealership. Tell him not to use aftermarket for that, they have a nasty habit of causing more problems.
Old Feb 2, 2014 | 06:05 PM
Vinford's Avatar
Vinford
Its been changed theres a list of stuff in my first post he already did.
No scanner and no easy access to one , so that's why he was trying a few things before getting it towed to Ford
Old Feb 2, 2014 | 06:08 PM
Pikachu's Avatar
Pikachu
OK. Well, if all that has been done, I can't think of anything that stands out as a smoking gun. Did he mention whether the SES light came on or not?
Old Feb 2, 2014 | 06:10 PM
JWC 3's Avatar
JWC 3
Heck .. Buy an inexpensive code reader before you have it towed .
