Need quick help -towing
Old Feb 2, 2014 | 10:57 AM
mo76's Avatar
mo76
For the life of me, I can't find the towing capacity for my truck. Please help. I want to tow a 3500 LB camper. My truck is 1976 F150 2x4 360 motor.
Thanks!
Old Feb 2, 2014 | 11:02 AM
61steven's Avatar
61steven
It should be on your door tag
Old Feb 2, 2014 | 11:49 AM
iggybob44's Avatar
iggybob44
A 360 has plenty of torque to pull a 3500 trailer......ideally you have either an Auto or a 4 spd manual, both are better suited to towing than the 3 on the Tree tranny. The door tags will list GVWR, not towing capacity. Personally, id want brakes on a 3500 lb trailer, surge are okay, but id prefer electric trailer brakes and a brake controller in cab. Make sure your cooling system is working properly, check brake fluid level, and adjust your tire inflation up to pretty much maximum inflation pressure as per the tire sidewalls
Old Feb 2, 2014 | 12:09 PM
gatorfor88's Avatar
gatorfor88
And dont forget when you are towing you have the trailer back there. That may sound dumb but it happens. A 3500 pound trailer will try to push a 1/2 truck.
Old Feb 2, 2014 | 01:55 PM
User 71024's Avatar
User 71024
only thing I'd add is +1 on the electric trailer brakes, and buy some minimum 8-10 ply tires, it makes a world of difference when towing heavy. I actually have 12 ply's on mine. Some of these so called LT tires are glorified car tires with light sidewalls.
Old Feb 2, 2014 | 02:29 PM
iggybob44's Avatar
iggybob44
12 plys? are you running 19.5 tires, cause almost nothing else in a current 16, 16.5, 17, 18 inch size goes over an E, 10 ply rating?
Old Feb 2, 2014 | 02:39 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
For 1975, the F-150 was introduced; as part of an effort to circumvent upcoming emissions requirements, the F-150 was designed with a heavier maximum payload (2,275 lb (1,032 kg) when properly equipped) than the F-100. With the half-ton F-100 still in production, the new F-150 was referred to as the "heavy half-ton."
The F-100 had a gross vehicle rating of up to 5,500 lbs.
Standard Catalog of Light-Duty Ford Trucks 1905-2002 - John Gunnell - Google Books
Old Feb 2, 2014 | 09:25 PM
rockittsled's Avatar
rockittsled
thanks to my owner's manual (thank you Cracker289), I can tell you what it says
for an f100/150 with the LD pkg with a 4950 GVWR, max is 2000 lbs
for an f100/150 with the HD pkg with a 5500 GVWR, max is 6000 lbs, but it specs an aux tranny cooler and 800 lbs max tongue weight within the hitch class
Old Feb 2, 2014 | 10:30 PM
77&79F250's Avatar
77&79F250
Is this a one time deal or a new hobby, cause 10 ply tires and elec trailer brakes are a very good idea.
With out anti lock brakes on your truck you need to drive smart and very defensive.
Old Feb 3, 2014 | 04:37 AM
User 71024's Avatar
User 71024
they are 16" , I bought 16" rims for the f-150, I'll tell you what they are a little later today, can't remember right now.
Old Feb 3, 2014 | 06:24 AM
User 71024's Avatar
User 71024
I evidently lied, they are actually load range E, 10 ply's. Sorry for the confusion.
Old Feb 3, 2014 | 03:00 PM
gatorfor88's Avatar
gatorfor88
Dang Eric, dont be lyin now.
I have a friend named Eric I say this to alot.
xzsbkn
2015 - 2020 F150
26
May 6, 2020 05:28 AM
sedwardson
Jun 5, 2008 04:01 PM
wolfey812
2004 - 2008 F150
Jan 28, 2008 09:39 AM
truckman87
Aug 4, 2005 12:42 AM
cbears
All Things Towing
16
Feb 6, 2003 03:16 PM
