Sponsored by: Real Truck
Experiences/opinions needed
Old Feb 2, 2014 | 09:23 AM
Boo153's Avatar
Boo153
I own an f250 with the 6.0. I'm now being told it will cost more to fix than its worth. My truck is my Dailey driver, I out on about 18000 a year. About a dozen times a year I also haul an aluminum 4 horse gooseneck loaded with also all the crap a bunch of teenage girls can pack. I'm finding the 2011 diesel which I liked but hearing horror stories about how they are now more complicated than gas engines and I'm looking at a 2011 gasser with the 6.2. Both trucks have 100000 miles on them but are in my price range. With the associated costs of diesels plus fuel now being more expensive than gas but towing better and gas being cheaper to maintain but worse mileage, I am absolutely at a loss on which one is better suited/ more economical for me.
Help!!!
Old Feb 2, 2014 | 10:19 AM
sammy77's Avatar
sammy77
Unless you're towing for a living, a gas truck will almost always be more economical. I don't know how well these trucks were maintained, but there are plenty of 6.2 & 6.7's out there with well over 100k on them. We have a '11 F450 6.7 car hauler, that's close to 210k with very little issues getting it there.
For what you describe, buy a gasser.
Old Feb 2, 2014 | 11:15 AM
dscabra's Avatar
dscabra
Diesels definitely have more maintenance costs than gas engines, and are more complicated to work on (more expensive to repair). An oil change on my 6.0L is $100+, fuel filters are $175+, etc. As much as I love my diesel truck, if budget was a major concern I'd be driving a non-diesel, and probably a 1/2 ton vs. the SD. I rarely tow anything and when I do, it doesn't require the towing capacity of my truck.
Old Feb 2, 2014 | 11:26 AM
Boo153's Avatar
Boo153
When I tow, it's 15000 pounds. Not sure a 150 would hold up or I would be looking at them. They are MUCH cheaper
Old Feb 2, 2014 | 11:34 AM
jeepnford's Avatar
jeepnford
I have a 7.3 diesel which has been a very good truck but is wearing out. I'll soon have a gas truck because I don't tow much any more and only drive about 4 miles to work. If I towed frequently or took longer trips I would have bought another diesel. I think this is a decision you'll have to make depending on your needs.
Old Feb 2, 2014 | 12:27 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Just because something costs more to fix than it's worth to someone else doesn't mean it doesn't make sense to fix. A drop-in ready 6.0 is like $13k (worst case), yeah that's a lot but compared to the cost of an entirely different used truck it's not as bad. New engine for less money, or 100k used engine for more? All of this is dependent on the chassis being worth keeping on the road for another 100k, but if you can pay less to hit reset on the engine instead of buying into something beat up it might make sense.
I'm not saying that because I'm in love with the 6.0L, I'd say the same thing about a blown 6.8 that you could replace for less than buying a 100k used one.
Either you're exaggerating, or you're getting bent over by someone.
Ford 6.0 Liter Turbo Diesel Motorcraft FD-4616 Fuel/Water Seperator Filters(FD4616): Pick Up & Excursion-REPLACES MOTORCRAFT FD-4604-NEW UPDATED - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
[PFF-4616] - Racor PFF4616- Ford 6.0 Liter Turbo Diesel Fuel/Water Seperator Filters: Pick Up & Excursion-REPLACES FD-4604/FD-4616 - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Feb 2, 2014 | 12:57 PM
dscabra's Avatar
dscabra
My local Ford Quick Lane charges $175.00 for a 6.0L fuel filter replacement (parts & labor). I guess I should do it myself next time.
Old Feb 2, 2014 | 01:09 PM
texastech_diesel
Token Redneck
Holy ****. Yeah man, it's only $36 for both filters and all you need is a flex head ratchet with 24mm and 36mm sockets. 30 minutes tops, if you try to be really clean and not spill any diesel out of the HFCM.
If you don't have either of the sockets:
S3624, Socket, Filter Flip, 24 and 36mm, 3/8" square drive
It needs a 1.5" 3/8" extension, or longer. Don't use the square drive in the secondary cap, you'll crack the cap.
Old Feb 2, 2014 | 10:35 PM
dscabra's Avatar
dscabra
Thanks! I'll be ordering that flip socket tonight!
Old Feb 3, 2014 | 10:12 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
What is wrong with the motor?
Old Feb 3, 2014 | 10:26 AM
Boo153's Avatar
Boo153
Nobody seems to know. They just want me to buy a new motor/new truck. I'm now hearing that maybe 2 bad fuel injectors
Old Feb 3, 2014 | 02:46 PM
El Camino Man's Avatar
El Camino Man
Even if its head gaskets, its fixable. There are tons of horror stories of 6.0s going bad but the vast majority of them are fixable. Unless something is wrong with the bottom end (spun bearing, thrown rod, etc) fix it and call it a day
Old Feb 3, 2014 | 03:59 PM
meborder's Avatar
meborder
i understand what you are saying, but that doesn't work for everyone. i know it wouldn't work for me at this point.
if he fixes his truck, he has to come up with $10k cash. if he buys a different truck he can get a loan.
i don't have that kind of money laying around to fix a truck, and i'm for sure not spending $10k to fix a truck, even if it is worth $10k or even a little more. to me, that's a project for someone else -- perhaps someone that can do it for half that and come out ahead. JMO.
I don't think I'd have a problem buying a Gasser with 100k on it if the rest of the truck was nice and it appears to have been well-kept.
there is a TON of value in a vehicle that is newer but has some miles. I don't see a lot of trucks that wear out anymore, even gassers that get worked hard every day. they might get old and have other problems, but it seems like the drivetrain is the last thing to go on modern vehicles.
i'd MUCH rather have a newer truck with more miles, than an older truck with a new engine. Just do your best to try and make sure they weren't beat to death, but that's buying ANY used vehicle.
Old Feb 3, 2014 | 04:05 PM
Boo153's Avatar
Boo153
Thanks mike, that is my problem in a nutshell. Payments on a newer one I can handle, coming up with 5 or 6 grand to fix mine, I can't. Haven't gone to look at this gasser yet. Apparently it was a government lease? Dealership has good reviews.
Old Feb 3, 2014 | 04:36 PM
Km1210's Avatar
Km1210
So why don't you bring your truck to a different mechanic and get a second opinion before you go buy another truck, unless you really just want a new one.
Stealerships aren't the best place to take your truck to.
We need more info. What problems are you having with your truck that made you take to to mechanic?
