83 ford f250 spark problem
Old Feb 1, 2014 | 08:36 PM
Alinebaugh1's Avatar
Alinebaugh1
83 ford f250
I have a 83 ford f250 with a 351 v8 and a 4 speed trans trying to get it to run it doesn't have any spark when the ignition is in the crank position but has soon as I left off and the ignition goes to run it sparks. Any suggestions?
Old Feb 1, 2014 | 09:10 PM
ctubutis's Avatar
ctubutis
Alinebaugh1, welcome to FTE.
But I deleted two of your redundant threads with the exact same question, asking the same thing multiple times won't get you any better or faster answers....
Old Feb 1, 2014 | 09:11 PM
Alinebaugh1
Sorry wasn't trying to put the same thing up multiple times .
Old Feb 1, 2014 | 09:22 PM
fellro86's Avatar
fellro86
I am assuming you still have a Duraspark ignition, so as such, there are 2 inputs to the DS box, one is when the key is in crank, it supplies 12V to the box. When the key is turned back to Run, the resistor wire is used, and reduces the input voltage. So one of two things here is likely to be happening: Either the DS box is bad, or the ignition switch/wiring to the box is bad. The box can be taken to most parts stores and tested. The wiring and switch can be tested with a test light to verify there at least is power getting through. This would be the 2 wire plug on the ignition box.
AerostarDad
Jul 9, 2009 11:57 PM
purplegoat
1978 - 1996 Big Bronco
Aug 10, 2008 04:04 PM
movieprops
Jul 17, 2006 04:39 PM
fdilley
15
Apr 15, 2006 11:35 AM
bear1956
May 20, 2005 01:18 AM
