ignition problem
Old May 19, 2005 | 09:10 PM
bear1956's Avatar
bear1956
Unhappy ignition problem
I have a 1987 f150 v8 351 at,ac.no start,After cranking a spark will jump the gap of the test tool with the ignition switch in the run position,then when switched to the off position another spark will jump the gap.I have changed the module,coil,plug wires,ignition switch,starter solenoid. please help.
Old May 20, 2005 | 01:18 AM
95X15's Avatar
95X15
Search for ignition system info provided by "fefarms" - just use his name and you will get tons of info. From his info I have read sounds like the distributor pickup may be bad - he provides detailed troubleshooting procedures in his posts.
