1978 - 1996 Big Bronco
electric fuel pump always running?
Old Feb 1, 2014 | 04:35 PM
flysf150's Avatar
flysf150
I just bought a 96 EB with 351. I started it up this morning and heard what sounds like a high pitched whine, coming from the rear of the truck. almost like an electric motor. any suggestions? as soon as it stops raining, I thought I would pull the fuel pump relay and swap it for the ac relay to see if the noise stopped.
Old Feb 1, 2014 | 04:43 PM
gatorfor88's Avatar
gatorfor88
Thats kind of how fuel pumps work. Key on, pump on. You should always keep fuel in vehicle so it helps keep pump running cool.
Old Feb 1, 2014 | 04:45 PM
flysf150's Avatar
flysf150
audible pump noise tho?
Old Feb 1, 2014 | 05:08 PM
gatorfor88's Avatar
gatorfor88
As to how loud it is I can not say. Any vehicle I have ever owned with fuel pump in tank was audible as far as I can remember. As I stated before keep fuel in tank at least 1/4 to help pump run cool. I cant speak as to the truth of whether this actually adds to longevity, but it is something I have heard over the years and it makes sense. Maybe someone who is a Pro mechanic will chime in here and help you out. I am just a backyard mech who keeps his own junk running.If it has points,plugs,carb and distibutor I can work on it. New computer controlled stuff I sometimes have to get a pro to diagnose.
Old Feb 1, 2014 | 05:31 PM
greystreak92's Avatar
greystreak92
Yes, it is audible when it is running. Noise level is not indicative of failure.
Old Feb 1, 2014 | 05:46 PM
peganit2's Avatar
peganit2
Every Ford's in-tank fuel pump for fuel injection that I have heard, and I do hear most of them turn on when I turn the key to run, shuts off after a predetermined amount of time if the computer doesn't sense that the engine has started.
It's a safety feature.
If yours continues to run even though the motor hasn't been started, something is wrong.
Coverbrooke
Apr 13, 2012 06:54 AM
aaronlockhart
Dec 31, 2008 06:23 AM
htcsusn
Jan 3, 2007 06:57 AM
justseggy
Nov 17, 2005 11:27 AM
OJ_Bronco
Dec 22, 2003 10:20 AM
