transmission oil
Old Feb 1, 2014 | 02:23 PM
traxx808's Avatar
traxx808
transmission oil
How many quarts of trans oil does a 94 f150 use ? I heard of 8-9 to 12. What is it really ?
Old Feb 1, 2014 | 02:31 PM
Evan_P's Avatar
Evan_P
8-9 if you only drop the pan. If you drain the torque converter as well your looking at 15-16 quarts. When I did mine I bought 20 quarts, dropped the pan, drained the torque converter, drained the cooler and added an external filter. I also drained my transfer case and refilled it. I used a total of 18 doing all of that to get it back to the right level. I highly suggest buying a pan with a drain plug when you drop the old one. It will make things MUCH easier the next time you do it.
Old Feb 1, 2014 | 04:27 PM
traxx808's Avatar
traxx808
Thanks for the help there Evan. I'll get that pan with a drain plug
joshofalltrades
Mar 25, 2013 05:56 AM
Powerstroke-7.3
48
Jun 14, 2010 08:00 PM
Todd525
Jan 21, 2008 08:08 AM
ALAN_50501
1997 - 2003 F150
Jun 25, 2006 12:02 PM
heavymetal
Jan 7, 2001 04:23 PM
