AC/Pump removal - pics
Old Feb 1, 2014 | 01:52 PM
wasatchjon's Avatar
wasatchjon
Hi all,
I'm about to perform my first engine pull/swap on an 89 F250, ZF5, 5.8 EFI. Motor in car is tired and needs to be rebuilt. I have a 'lightly used' 5.8 from the same year/model F250 that I would like to try in the car before rebuilding the original 5.8...so I'm going to throw the spare motor in and see how it runs. Before doing that, a few questions:
I was told that the air pump was having 'issues' when this motor was pulled, so I'm going to remove it, the egr and leave the AC out. Just to make sure I understand the process... All I need to do is remove the pump, all of the associated tubing and plug the holes in the exhaust headers right?
Below are 3 pics which outline what I'm describing.
Also given that this motor has no AC and will not have a pump anymore...what belt should I use?
Thanks for any/all guidance. Also feel free to make fun of the leaves or my disorganized garage.
Old Feb 1, 2014 | 02:13 PM
Island'r's Avatar
Island'r
Confusing post... You are removing the air pump, and then in the same sentence you say AC...
A/C is the air conditioning pump. The pump you are reffering to is the "Air Pump" or "Smog Pump"
Just thought I'd point that out for clarification...
Old Feb 1, 2014 | 02:25 PM
Evan_P's Avatar
Evan_P
If your going to run without both, buy an A/C idler pulley. Then take a piece of rope/string and run it through the pulleys. Measure rope/string and there is the rough estimate of length.
Old Feb 1, 2014 | 05:23 PM
wasatchjon's Avatar
wasatchjon
Thanks for the replies. You have found my main problem, I am new at this and bad at nomenclature...which is why the searches haven't helped me 100% and why I'm posting my questions with pics.
Yes, I meant both the AC and the air/smog/Kalifornia pump.
I will buy an AC idler pully and measure the string, thanks for the suggestion.
A few small questions remain though: Do I just tear everything else off up there? What would you use to fill the holes in the exhaust headers?
Old Feb 1, 2014 | 06:11 PM
danr1's Avatar
danr1
Had to replace an idler pulley on my 94 5.8L, it does not have AC never did and that is the idler I needed.
Bought a replacement pulley at Napa, it includes the bracket you'll need.
In fact they could not get me that idler pulley only which I found to be odd, no ac so I didn't need the bracket. Apparently the only way they offer that pulley is pre mounted to its bracket.
So naturally some place around here stashed on a shelf, lays a AC delete bracket in the box, that new one had to buy but didn't need!
mramc1
64
Jun 23, 2021 02:34 PM
85MOTORSPORTXLT
1978 - 1996 Big Bronco
Aug 9, 2016 03:58 AM
JGreen236
Jan 5, 2010 04:34 PM
JRCF
Jan 15, 2008 11:56 AM
chrono4
Jan 9, 2005 04:10 PM
