6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Need help
Old Jan 31, 2014 | 10:22 PM
mrvega29's Avatar
mrvega29
Need help
How do you bleed a feel system on a 2008 6.4 after disconnecting the fuel lines
Old Jan 31, 2014 | 11:27 PM
9228.bobcat's Avatar
9228.bobcat
What fuel lines did you disconnect? If you have air in the low pressure side you can use the Shrader valve on the fuel cooler. Just cycle key when valve is pressed in and cycle for 30 sec or so or until you cant hear bubbles coming out. If it is in the high side you have to loosen the banjo bolt on the fuel cooler while you cycle the key until there is no more bubbles. Low pressure first then high pressure
Old Feb 1, 2014 | 07:04 PM
senix's Avatar
senix
the manual talks about how to purge the air after a fuel filter change. You cycle the key to just the on position about 6-8 times.
Each time you move the key to the on position (without attempting a start). You hold it there for around 30 seconds, giving the low pressure pump time to circulate and send the fuel to the top mounted filter.
After you do this routine then you can attempt the start.
Old Feb 1, 2014 | 07:10 PM
9228.bobcat
Well senix I think he dissappeared. Seems to be the trend. Ask a question and good bye.
Old Feb 1, 2014 | 07:19 PM
senix's Avatar
senix
could be...maybe he will sign on later and see the info. Might be working on it right now.
I know my first fuel filter change I could not get it to purge...ended up hitting the fuel cutoff switch and held it down while cranking and finally got it to fire.
Old Feb 1, 2014 | 07:36 PM
9228.bobcat
Yea sometimes they can be a pain. Kinda of curious of which lines he unhooked. Hate for him to push air to his high side. Maybe he will get back on. Later bro
terrymargate
6.7L Power Stroke Diesel
Feb 1, 2018 08:54 AM
rv8riveter
Modular V8 (4.6L, 5.4L)
Aug 7, 2011 12:33 AM
mriplaybass
Jan 5, 2011 07:39 PM
John7894
22
Apr 5, 2010 11:08 PM
1998ranger3.0
1983 - 2012 Ranger & B-Series
Jun 1, 2009 05:03 PM
