Gas Gaskets
Old Jan 30, 2014 | 07:53 PM
84espy's Avatar
84espy
Gas Gaskets
I will be installing my new 38 galnk on Monday. I am thinking of making my own gaskets. What would the proper material be and what kind of sealant?
Old Jan 30, 2014 | 08:57 PM
fmc400's Avatar
fmc400
MSEE
Does "galnk" mean "gas tank"? What's a "gas gasket"? Gasket for what? There's an o-ring for the sending unit; that's it. What am I missing?
Old Jan 30, 2014 | 09:08 PM
84espy's Avatar
84espy
It should be gal tank. My keyboard is getting worn out. I was wondering if there were any gaskets that needed to be put on prior to installing in the truck.
Old Jan 30, 2014 | 09:16 PM
co425's Avatar
co425
The only gasket I know of is for the sending unit.
Old Jan 31, 2014 | 03:27 AM
USArmyTaterness's Avatar
USArmyTaterness
A couple of bike inner tubes cut to fit make good isolators for the tank staps
Old Jan 31, 2014 | 12:56 PM
84espy's Avatar
84espy
Thanks for the replies. One last question:
will the bronco sending unit work with this tank? I found a few broncos at the yard (done in by the seahawks ) and i'm thinking about picking up the skid plate and a sending unit, if it fits.
Old Jan 31, 2014 | 06:44 PM
79FordBlake's Avatar
79FordBlake
What is this going in? 78-79 Broncos could have either a 25 1/2 gallon tank or 33 gallon tank. You need the right sending unit. 33 gallon is more common.
Old Jan 31, 2014 | 07:54 PM
84espy's Avatar
84espy
I'm putting in a 38 gal tank. What is the depth difference between the two on the bronco?
Maltman
Mar 27, 2015 09:31 AM
jrmwilson
19
Mar 24, 2013 11:49 PM
pcwb
Sep 25, 2006 06:35 PM
cheinz46
May 10, 2004 10:30 AM
koshare
Jan 2, 2004 03:28 PM
