00 3.0 Ranger Automatic Starting issue
Old Jan 30, 2014 | 06:00 PM
andyinAZ's Avatar
andyinAZ
I have a 2000 3.0 Auto Ranger with 162k miles.
I guess it has to be in "Park" in order to start.
Lately, I've been having to periodically wiggle the gear selector for my auto transmission in order to start it.
It seems to be getting progressively worse.
Any ideas? Thanx!
Old Jan 30, 2014 | 06:09 PM
JWC 3's Avatar
JWC 3
Could be a PRNDL switch failing . Slop in the shifter asy. is something common to look for also . I would check for slop first .
Old Jan 30, 2014 | 06:19 PM
andyinAZ's Avatar
andyinAZ
Yeah, it seems that the column shifter is not snapping convincingly into park. Like something is loose, so I have to play with it until I get in right. Otherwise it won't start.
How do I check/fix slop in the shifter say?
Much THANX!
Old Jan 30, 2014 | 06:26 PM
JWC 3's Avatar
JWC 3
Not too familiar with their shifter column , I don't see many , look where the shift cable attaches at the column . The mount may be loose . There can also be issues with Bushings and such in the column .
Old Jan 30, 2014 | 06:59 PM
andyinAZ's Avatar
andyinAZ
Ok I'll poke around and see if I find anything loose.
Thanx!
Old Jan 30, 2014 | 07:12 PM
JWC 3's Avatar
JWC 3
Best of luck ! Let us know what you find .
Old Jan 30, 2014 | 07:55 PM
Rockledge's Avatar
Rockledge
As mentioned, it could be a gearshift select issue. Check out: https://www.ford-trucks.com/forums/1...s-in-park.html
This video shows the fix on a Superduty/Excursion but it's the same thing on the Ranger:
Old Jan 30, 2014 | 08:24 PM
andyinAZ's Avatar
andyinAZ
Thumbs up Thanx!
Schweet! I'll check it out Thanx!
teamlx88
Jul 20, 2014 01:49 PM
pizza guy
May 20, 2011 11:03 AM
sealer187
Jul 30, 2008 10:09 PM
jhjandal
Aerostar
Jun 20, 2005 09:58 PM
cherokee
Sep 17, 2002 07:39 PM
