I have a 2013 F250 4x4 6ft bed near enough standard. I intend getting a 36ft Raptor Toy Hauler. My problem is: On the sticker on the lower B pillar the GVWR is 10000lbs. On the website it is either 14000 or 15900, (can't be sure). I have read elsewhere 18000. The brochure is 15900, The RV is 16900. All the RV dealers I have spoken to say the 250 will tow these easily.
I am a complete novice when it comes to all this so would appreciate good advice, without all the technical bumf that goes with it.
My questions are,
1, what are all the acronyms? ie: UVW, GVWR etc
2, Will my 250 pull this RV safely and legally in the US
3, As the truck is new (ish) can anyone tell me a quick and easy way to increase my trucks towing ability?
Have you looked in your owners manual? Within the 1000 pages of unneeded info, theres surely a towing capacity in there somewhere!
If you find something labeled GCWR, this is your answer! This is the Gross Combined Weight Rating, i.e. total weight of your truck and trailer. Take this number minus your GVW (Gross Vehicle Weight) and vua-la! Your answer of how heavy of a trailer you can tow!
My questions are,
1. Gvwr is gross vehicle weight rating, which is what the vehicle can weigh fully loaded. Gcwr is gross combined weight rating and that's what you can be as one unit, truck and trailer.
2.you'll have to look at the towing brochure and see what your truck is based on cab configuration, axle ratio and motor if its 15900, and the trailer is 16900 I'm going to say no but I don't know what number your referring to tow capacity and gcwr will mean critically different things
3. Nothing. You can only legally carry so much. If it ends up being too much, you'll need a 350 or 450 or a different trailer.
You're going to be over. Figure 8000# on the light end for the truck leaves you 2000 payload, which is only going to be around 12% of the trailer weight on the pin which is way light for an RV.
But I've never seen an RV at a weigh station or talking to a weight cop.
Thanks everyone for your answers, The manual says to look at the plate on the B pillar and that is 10000, so I think really I need a bigger truck or smaller RV
Well that's your truck. Not what you can tow. But that leaves you about 2000 lbs as payload
Study the Towing Info on post #5 (based on truck configuration /engine / rear axle ) . Never trust a dealer about towing info.
Also, do yourself a favor and get your next truck with a long-box (if you are going to haul a 5er). Sometimes they may fix you with ; 1- an extended pin box (on RV) , 2- a slider 5'er hitch (in truck box) . That will still be a compromise and you can not jackknife when backing into tight spaces and you will damage your cab .
You must not have traveled in the North Central US then. I see signs all the time when I drive the interstates that say vehicles over 8000 lbs or pulling trailers must exit at weigh station, this includes RVs. I believe I-80 and I-70 have these signs. I drove so many interstates up there and I wasn't pulling - so I can't help there.
Your other problem will be if you get into an accident.
RVs do not have to stop at weigh stations. If you're seeing RVs in a weigh station, they're probably RV transporters. These guys transport RVs from the manufacturer to dealers. Even though they're towing an RV, they're getting paid to haul it from point A to point B, which makes them a commercial vehicle. That's why they have to stop.
I see those signs also, but the stations are never open.
As far as an accident......I hear this all the time, but I have never heard from anyone driving a pickup and towing a travel trailer getting a ticket, warning, fine violation or severe scolding for exceeding the manfacturer's recommended maximum towing weight, or being held liable because they were in an accident and were over that magic GCWR.
If you can prove otherwise, please do so. All I ever hear are 3rd hand accounts of "my coworker's brother" but no first hand accounts.
That being said, I don't recommend towing over the rated GCWR, unless you're very sure of your equipment, route and your load. A 16,900# 5th wheel (dry weight?) should be towed by an F-350 Power Stroke DRW, minimum.
Just for comparison I tow a 14,000 42' GN and fully loaded cat scale verified I am at 22450. My rear axle weight rating is 500 under the door sticker. I would not want to add 2k more that your RV weights. I think your truck is below your needs or your trailer is to heavy.
Nope...if you are private you don't stop. People moving with a uhaul don't stop-private.
