"94 351w check engine light
Old Jun 2, 2002 | 03:38 PM
Domino's Avatar
Domino
Several weeks ago I started getting an intermittent check engine light
I have a "94 F150 w/351 engine. The light comes on only when cruising or light acceleration, never at idle or full acceleration. I checked the code and it is a code 173 (lack of oxygen sensor switches - rich - right side). I have also noticed that the engine seems to surge a little at cruising. The truck has 81,000 miles . I went ahead and changed the plugs, plug wires, distributor cap & rotor to no avail...
Can anyone offer any suggestions what I need to be looking for ???
Domino
Old Jun 2, 2002 | 06:42 PM
groundrat's Avatar
groundrat
Haw you tried reading the codes yet? There is a very simple procedure to have the check engine light flash out the fault codes. If you have a Chiltons, or Haynes manual for your truck it is in there. Try that and post the codes here and we will try to help.
Bill
Old Jun 3, 2002 | 05:14 PM
Domino's Avatar
Domino
I pulled the code and it is a code 173 (oxygen sensor right side- rich)
Old Jun 3, 2002 | 06:32 PM
rc351w's Avatar
rc351w
Domino
Aug 8, 2015 12:58 PM
Domino
Jul 18, 2015 08:38 PM
Domino
Mar 27, 2015 03:15 PM
Domino
Electrical Systems/Wiring
Feb 11, 2003 11:21 PM
Domino
Jun 3, 2002 11:56 PM
