Thinking about new rims and tires for my 04 f150
I have an 04 F150 2wd ext cab. I have my eye on some 18" black wheels that are 9" wide. I will be leveling the front with a 2 inch lift and want to put the biggest a/t tire possible without any rubbing issues. I'm not dead set on these particular wheels so if they are too wide or whatever I can explore other options. Please advise tire size or if I should pick different rims. Thanks for your time
Sorry, you're right. 305/60/18 or 305/65/18 depending on tire availability. My apologies as 20" is just embedded in my brain.
Backspacing is the relation of the wheel's hub flange in relation to the inner and outer lip of the wheel. Google it and you'll see what I mean. Are the 18" wheels you're eyeing factory or aftermarket?
Depends on the wheel. Factory wheels?...likely. Most of the factory wheels are +44mm offset, so if you came back on an aftermarket wheel to say +18, +20 or even +30 you probably won't rub the control arms. The closer you get to 0 offset then the more chance you take of rubbing the lower portion/edge of the bumper and fender wall. + offset puts the wheel closer to the truck, while - offset puts the tire away from the truck.
If your going 18 got with 275/65/18. Its a 32.something inch tall tire but it almost 3-400 dollars cheaper than a 275/70/18 wich is a 33. I wish I could post pictures off my phone on to here because I have a picture of a guy off of south park saying if you lift your 2 wheel drive truck your gunna have a bad time. Haha all jokes aside youll be just fine. Also l went from running 305/55/20 to a 275/70/18 and I would stick with a 275. Less rolling resistance = better mpg
1979FordF-250Custom
06-09-2013 12:24 AM
1979Mustang
03-04-2011 08:32 AM
Martin97C5LS1
2004 - 2008 F150
10-09-2009 10:29 PM
