C6, part behind the pump?
Old Jan 29, 2014 | 01:02 PM
shane_lxi's Avatar
shane_lxi
I'm new to automatic transmissions, but i figured I could probably replace my front pump seals. I think I should have stood it up on its tailshaft when I took the pump out. There's a big drum shaped piece that kind if came loose. I think I got it back where it goes (slips into some recesses) but I'm not sure. Does the alignment of this piece matter?
Old Jan 29, 2014 | 05:10 PM
cammok5's Avatar
cammok5
C6 Parts Blow Up Diagram
its been awhile since I rebuilt my c6 but this may help.
the drum # 74 has cluth plates in side with splines that slide over the splined part if #68. make sure every clutch plate is on the splines or there will be clearance problems.
as far as a clocked postion it doesn't mater, it will spin or lock up depending what gear you are in.
Old Feb 13, 2014 | 02:50 PM
shane_lxi's Avatar
shane_lxi
The only thing I can see that looks out of place is one washer at the bottom. I've moved it around a lot and it doesn't seem to snap into anything. Its on the too left of this picture:
imgur: the simple image sharer
I'll take a pic if my transmission in a few
acw5021
Oct 31, 2024 10:15 PM
87f350banksequiped
Jan 18, 2010 06:54 PM
drunknmudder77
May 26, 2006 07:46 AM
TractorGuy
Jul 30, 2002 03:37 PM
wiseblood
Mar 20, 2001 08:35 PM
