C6 Front Pump
Old Mar 15, 2001 | 02:17 PM
wiseblood's Avatar
wiseblood
C6 Front Pump
how hard is it to replace the front pump for a C6 tranny
i have the front pump I just need to know what to look for in the problems i may run in to i havent work on it befor
thanks for any help
Eddie
Old Mar 16, 2001 | 10:22 AM
oz9609's Avatar
oz9609
C6 Front Pump
They are not hard to replace. Tell why you are replacing it.
Old Mar 20, 2001 | 01:52 PM
rustbukt's Avatar
rustbukt
C6 Front Pump
If you aren't careful, the gear packs inside will disengage. I'd recommend doing this with the tranny standing on end (supported on case, not output shaft). If the pump doesn't slide in relatively easy, stop and look for reason why.
Also make sure you get three "clicks" when you reinstall your torque converter.
I learned this the hard way.
Old Mar 20, 2001 | 08:35 PM
toddmiller's Avatar
toddmiller
C6 Front Pump
9228.bobcat
Apr 26, 2015 08:38 PM
The Eddie
Oct 8, 2013 05:20 PM
ranman truck
New Member Introductions
Jan 28, 2008 07:14 PM
n8ster
Sep 14, 2003 10:45 AM
Eddie
May 12, 2000 10:18 AM
