00 F250 Problem.
Old Jan 29, 2014 | 09:39 AM
pin8246's Avatar
pin8246
00 F250 Problem.
Alright guys I have a problem. Still in the works of getting a A&E to get the codes, but this may be one you guys can help without it. Been going on for a while but seems to be getting worse.
Everything runs fine, but on occasion the throttle quits working. It will keep idling, but no response from the throttle pedal. Then after about a second the service engine light flashes, then the throttle pedal works again.
Reading on here, to me it sounds like the TPS. What do you guys think?
Old Jan 29, 2014 | 09:42 AM
HKusp's Avatar
HKusp
I think you nailed it.
Old Jan 29, 2014 | 09:46 AM
pin8246's Avatar
pin8246
Thats what I was thinking. Now where do I get one? Looking at the local chain stores around here they have the plug with wires connected for a faulty connector, but not the actual TPS. And reading on other post, some you have to replace the entire pedal assembly, how do I know which is mine?
Old Jan 29, 2014 | 09:49 AM
HKusp's Avatar
HKusp
I would try taking it apart and cleaning the contacts first. A lot of times, it's just some dirty contacts and it doesn't need to be replaced.
Old Jan 29, 2014 | 09:50 AM
pin8246's Avatar
pin8246
Sounds good. Ill try that when it warms up, thanks for the help.
Old Jan 29, 2014 | 09:55 AM
HKusp's Avatar
HKusp
You are welcome. They have different versions depending on what year truck you have, if I recall correctly. Here are a few that Summit carries. I am pretty sure you can find a better price from somewhere else.
http://www.summitracing.com/search/p...350-super-duty
guitarpicr
Feb 26, 2017 08:02 AM
HighOctane
6.4L Power Stroke Diesel
Jul 31, 2014 07:29 PM
Craig64
Jan 17, 2008 04:51 AM
HighDesert
Sep 18, 2007 10:03 PM
twinsfd
Dec 23, 2006 04:37 AM
