Had a problem with truck service engine light would come on, no throttle response. Bought new throttle pedal at the dealer thinking this would solve problem, mounted throttle pedal now its not working at all.
Questions- Do I have to get this pedal recoded by dealer computer to work? or is this a plug and work pedal?
Did you check all your fuses, I know there is one that controls the go pedal, but not sure which one. When I was hooking up my gauges I accidently pulled the wrong fuse out and didn't have any throttle, it would start and idle just not throttle response.
look at the terminals in the connector that plugs into the pedal.make sure the termanal hasnt spread open to much making a bad contact.this is a problem i have seen in the dealership.
