ranger issues
Old Jan 29, 2014 | 06:57 AM
Albert Sanchez's Avatar
Albert Sanchez
ranger issues
I own a 2003 3.o v-6 ranger, after a short or long drive, my truck has a hard time starting.. Starts fine before any driving.. PLEASE HELP
Old Jan 30, 2014 | 07:30 AM
Rockledge's Avatar
Rockledge
Is the check engine light on, or has it been on at all recently?
Does the "hard start" occur after every warm-up? Or only sometimes?
Old Jan 30, 2014 | 11:29 AM
cbenz73's Avatar
cbenz73
Elaborate on "hard start". Does it not crank, crank slow, crank good but not start, crank good but just doesn't wanna completely run?, ect.
Old Jan 30, 2014 | 03:14 PM
Albert Sanchez
2003 ranger issues
No, no engine light. And yes it happens all time after warmed up..
Old Jan 30, 2014 | 03:16 PM
Albert Sanchez
good cranking, just alot of turning over before starting..
Old Jan 30, 2014 | 03:30 PM
cbenz73's Avatar
cbenz73
Sounds like you may have too rich of a mixture maybe. Dirty sensors will sure do that.
Old Jan 30, 2014 | 05:17 PM
Albert Sanchez
Dirty sensors, Could you elaborate where I could look??
Old Jan 30, 2014 | 05:21 PM
cbenz73's Avatar
cbenz73
I'd probably start with the map sensor
Old Jan 30, 2014 | 05:24 PM
cbenz73's Avatar
cbenz73
go wot when you go to start it next time
Old Jan 30, 2014 | 07:41 PM
Rockledge's Avatar
Rockledge
The OP's '03 Ranger doesn't have a MAP sensor; instead, it uses a Mass Airflow Sensor (MAF).
Worth a shot. Pushing the throttle pedal all the way down during cranking (WOT) will prevent the fuel injectors from firing. This could help if the hard start is due to a fuel mixture that is too rich.
The flip side of that is, you can try turning the key on and off several times prior to cranking. This will (or should) cause the fuel pump to prime the system several times. This could help if the hard start is due to a low fuel pressure-type of issue.
Of course, neither of the above tips are as good as a good old-fashioned fuel pressure test, and so if you can get your hands on a FP tester, go for it.
Old Jan 30, 2014 | 09:29 PM
cbenz73's Avatar
cbenz73
Awe I see, haven't worked on the newer 3 liters. Could even be an issue with heat soak in your ignition. Oh the possibilities.
Old Feb 1, 2014 | 11:01 AM
Albert Sanchez
2003 ranger issues
So, if I do have low fuel pressure. What are my options?
Old Feb 2, 2014 | 12:46 PM
Rockledge's Avatar
Rockledge
First change the fuel filter and run some fuel injector cleaner through the system, and see if that helps; otherwise, you may need a new pump assembly.
Mike1998Ranger
Electrical Systems/Wiring
Sep 13, 2013 07:41 PM
hcraw4d
Dec 11, 2012 06:54 PM
DagotheGr8
May 31, 2009 08:38 AM
user 2833083
Aug 1, 2005 08:36 PM
