intake manifold
Old Jan 28, 2014 | 01:55 PM
friskyjake's Avatar
friskyjake
intake manifold
Son has a 1987 ford ranger 2.9 engine 5 speed 4x4 truck. See anti freeze leaking @ the rear of the engine where the intake attaches to the block. How long to re & re the intake, ect. Is it just gaskets or what? Is it a big job? thanks in advance friskyjake
Old Jan 28, 2014 | 04:43 PM
Monteg0's Avatar
Monteg0
Meh, if you're handy, you should be able to do it in an afternoon. And yeah, its essentially just gaskets
Old Jan 28, 2014 | 05:07 PM
friskyjake's Avatar
friskyjake
Are the aluminum intakes subject to warping? Thank you for the reply
Old Jan 28, 2014 | 05:09 PM
Monteg0's Avatar
Monteg0
TBH, i dont know. Did you overheat it?
Old Jan 28, 2014 | 09:24 PM
friskyjake's Avatar
friskyjake
No. My son bought the truck bran new in Oct 1987. We have kept up on all the maintenance. It is a very nice truck.
Old Jan 28, 2014 | 11:08 PM
Monteg0's Avatar
Monteg0
then yeah, just gaskets and you should be good.
Old Jan 29, 2014 | 07:46 AM
pawpaw's Avatar
pawpaw
If its just a weep, you might consider re-torquing the manafold fastners to spec in the specified sequence & see how it goes.
Old Jan 29, 2014 | 08:12 AM
Josh S's Avatar
Josh S
That is something to be proud of. Not many people have the patience/ability to keep a truck going that long. I hope the leak repair goes well.
Old Jan 31, 2014 | 09:02 AM
Ford Breakdown's Avatar
Ford Breakdown
Another advantage to this job: you won't *believe* the amount of gunk you'll find in that manifold between age, PCV valve and EGR. I had the manifold off my '86 last fall and went through 3 cans of carb cleaner getting it all out. It really is a pretty simple job.
Old Feb 1, 2014 | 04:20 PM
friskyjake's Avatar
friskyjake
I want to thank everyone for the advice that was given. The intake was removed & all gaskets replaced. No more leaks. Just time was needed. friskyjake
vaper
Large Truck
Nov 18, 2015 09:17 AM
fabieber
Sep 24, 2015 09:07 AM
ironhead86
Mar 6, 2009 05:48 PM
85lebaront2
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 22, 2006 05:25 AM
