Sponsored by: Real Truck
4x4 operation questions
Old Feb 1, 2014 | 12:16 PM
  #31
Dakster's Avatar
Dakster
The traction control on the new ones isn't much better. It makes you hop like rabbit and you still don't go anywhere.
The best I can do is 4-lo and electric locker engaged for the rear tires. 4-lo auto disengages traction control too which is a plus when stuck.
Old Feb 1, 2014 | 02:45 PM
  #32
artt's Avatar
artt
So now the next question about LS diffs (don't you hate the no-nothing newbies?) - what axles do I have? I've found a list of True Trac diffs, but there seems to be quite a few that might fit a 2005 F350, depending on the axle. All my door sticker says is 3L. How do I find out if I have a Dana 80, a Ford, etc.?
Old Feb 1, 2014 | 03:39 PM
  #33
Dakster's Avatar
Dakster
Might be stamped or on a little metal tag on the axle by the pumpkin...
Old Feb 1, 2014 | 03:51 PM
  #34
artt's Avatar
artt
Thanks. I'll try that when I can get, and keep, it clean enough to see something!
Old Feb 1, 2014 | 04:00 PM
  #35
Tom's Avatar
Tom
No reason to check the pumpkin. Do you have a DRW or SRW truck?
Old Feb 1, 2014 | 05:55 PM
  #36
EXv10's Avatar
EXv10
No we don't hate'em, we get them back on track.
Old Feb 1, 2014 | 06:22 PM
  #37
artt's Avatar
artt
Single rears.
Old Feb 1, 2014 | 06:23 PM
  #38
Tom's Avatar
Tom
Single rears.
Okay then. You have a Sterling(Ford) 10.50" rear axle.
Old Feb 1, 2014 | 06:29 PM
  #39
artt's Avatar
artt
Thank you. Now to find someone who can do the job at a reasonable price. Any idea how many hours a swop should take? I've tinkered with things like brake and alternator replacements but this is probably too complex for me.
Old Feb 1, 2014 | 06:35 PM
  #40
Tom's Avatar
Tom
That can be a tough one. It's not a very complex job at all but it requires a very high level of precision most of us just aren't comfortable with.
Old Feb 1, 2014 | 06:54 PM
  #41
Dakster's Avatar
Dakster
Unless someone else changed it out... I always like to verify.
Old Feb 1, 2014 | 06:56 PM
  #42
Tom's Avatar
Tom
I'm not aware of any other axle that'll fit under there. What could it have been changed to? Of course ratio changes are relatively common, it's pretty rare to hear of an axle swap unless it's replaced with the same one.
Old Feb 2, 2014 | 09:13 AM
  #43
Dakster's Avatar
Dakster
One never knows... I've seen all kinds of stuff in my years. I've seen Dually axles modified to put under SRW's. And F150 axles modified to put under SDs.
Never under estimate the "power" and surprise of backyard mechanical engineering.
Old Feb 2, 2014 | 09:25 AM
  #44
Tom's Avatar
Tom
One never knows... I've seen all kinds of stuff in my years. I've seen Dually axles modified to put under SRW's. And F150 axles modified to put under SDs. Never under estimate the "power" and surprise of backyard mechanical engineering.
Ha ha....you just reminded me of a thread I read on another forum. Some clown was putting a dually axle under his F150. Completely destroying a nice truck. Some people's kids...
HouseMouse
Jan 22, 2018 10:41 PM
DrCharles
Jan 15, 2018 09:58 AM
Frankievespa
Jan 30, 2011 08:48 AM
Pat_D
Dec 11, 2008 06:05 PM
