"New" van owner
Old Jan 27, 2014 | 02:23 PM
Gettysburg150's Avatar
Gettysburg150
"New" van owner
Hello all, I've been over in the pre-power stroke thread a bit and occassionaly in the 67-72 F100 and FE v8 threads. I've looked around a bit in here before purchasing the latest edition, but here she is!
Specs:
1989 Club Wagon (I'm assuming 3/4 ton, GVWR is 8550)
7.3 IDI E4OD
~129xxx miles
She has some issues (which I'm sure I will be asking about) but overall we are happy with our purchase. Plans include being a weekend driver, tow a horse trailer (eventually), and maybe go on some camping and riding trips.
-Jason
Old Jan 28, 2014 | 04:52 PM
JWA's Avatar
JWA
Looks good from this angle---and distance!
If the body is sound and no major rust issues it should give you more than a few good years for your intended uses. Mileage isn't excessive but since I know almost nothing about diesel engines tough for me to say anything about that part of it.
Hope to read more if you do anything even if its just routine maintenance---that's almost more fun to read about than do---sometimes!
Old Jan 29, 2014 | 09:24 AM
Gettysburg150
Thanks JWA,
She is def a 20 footer, good from far but far from good
Rust isn't too bad, about as much to be expected in the rust belt, actually less than I had anticipated which was a nice surprise.
I hope to be able to document some of the progress we hope to make in the goal of reliability and functionality. Come spring time the interior is getting gutted just so I can make sure I know where everything is, all the wiring is ok, and all the rust is found
Our fleet is pretty full and we don't plan on letting anything slip away
Old Feb 4, 2014 | 09:42 AM
Gettysburg150
This is a double post from the IDI thread, but I figure some of you may have experience and not visit over there...
Ok ladies and gents, opinion time!
I'm trying to get some stuff together for doing some services to the van. Things that require immediate attention (imo, correct me if I'm wrong) are the following:
Oil change (Going to use castrol 15w40 since I have it at work and a FL1995 filter)
Rear diff service (75w90 @ 4 qts correct?)
Trans drain and fill (14 qts of Mercon V atf?)
Coolant flush (opinions? Used Fleet Charge from TSC for the truck)
Upper and lower rad hose (opinions? want good but affordable parts)
Anything else to consider? This is our weekend vehicle now and the fiance's back up
85F150rd
16
Oct 3, 2018 01:00 AM
vettex2
19
Jul 21, 2015 08:51 AM
blageurt
Mar 31, 2013 05:26 AM
PStruwing
Feb 18, 2012 06:31 PM
wresleu
Aerostar
19
Oct 29, 2005 11:09 AM
