Distributor Shaft Size?
Old Jan 27, 2014 | 09:21 PM
Gary Lewis's Avatar
Gary Lewis
Originally Posted by bruno2
I was trying to cross the part number for a Standard Motor Products ignition module on Summits site. When I got close to narrowing it down all the sudden I was asked what Ford part number it was originally and was given about 30 different OEM numbers that had about 8 characters each in them. Turns out they all crossed to the same LX203 number for Standard. Then I took the part number and searched Amazon for it since I get free 2 day shipping with my Prime membership(also they seem to beat Summit's prices, but they don't have a search application for vehicles) that I cant use to watch movies with because my smart blue ray doesn't offer Amazon and doesn't have any software upgrades available.
I agree w/Jim. I have about 10 different vehicles in my garage at Amazon and it tells me if what I'm looking at fits or not. But, it isn't always right, so cross-reference.
As for watching Amazon, get a Roku, Apple TV, or even Google Chromecast although there are some issues with them I hear.
Old Jan 27, 2014 | 09:29 PM
bruno2's Avatar
bruno2
Originally Posted by brake4beaver
Shaft diameter 351w duraspark ll dist: 17/32", or 13.35mm, or .525". Oh and FYI, you can measure shaft diameter without touching the gear, it's the same as the portion above the gear. I measured both, they were identical.
Thanks brake for beaver!!
Old Jan 27, 2014 | 09:30 PM
bruno2's Avatar
bruno2
How do I make a profile for Amazon Garage. I haven't seen that option.
Old Jan 27, 2014 | 09:33 PM
bruno2's Avatar
bruno2
.531 is as close as Summit gets.
http://www.summitracing.com/search/p...rder=Ascending
Old Jan 27, 2014 | 09:37 PM
bruno2's Avatar
bruno2
Jegs has got a ton of .530 and .531 stuff. I am tempted to think these may work.
Old Jan 27, 2014 | 09:45 PM
bruno2's Avatar
bruno2
distributor+gear - JEGS High Performance
I am tempted to think it is .530.
Old Jan 27, 2014 | 09:50 PM
Gary Lewis's Avatar
Gary Lewis
On Amazon, once you have a part pulled up look for My Garage. I can't see where it is right now 'cause I'm logged in and it automagically checks anything I'm looking at against whatever vehicle I have selected. But you should be able to see the drop-down..... sorry, gotta go someone texted me. Oh, 'tis you. Yes, look for the drop down.
Old Jan 28, 2014 | 04:19 PM
Gary Lewis's Avatar
Gary Lewis
I miked it today at .536", so the .530 must be right.
Old Jan 28, 2014 | 05:50 PM
Franklin2's Avatar
Franklin2
I just looked up some distributors to answer a question another poster had(forgot what post it was) and noticed Autozone had a choice. You could get a dist with a cast iron gear or with a steel gear already installed. You might want to check their site and see what it says.
If your camshaft supplier recommends the steel gear, you need to use it. It needs to be right. If the camshaft has a steel gear and you put a cast iron dist gear in, it will eat up the cast iron gear. The reverse is also true, if your camshaft happens to have a cast iron gear and you put a steel dist gear in, the dist gear will eat up the camshaft gear. The load on it comes from the oil pump.
Old Jan 28, 2014 | 06:10 PM
bruno2's Avatar
bruno2
I have the high volume oil pump also.
Blown 331
Jun 29, 2019 06:12 PM
hermancm
May 16, 2012 10:29 AM
Specter
Bronco II
Oct 14, 2003 05:44 PM
F150Lariat79
May 19, 2003 09:09 PM
SKID
Jan 27, 2002 07:08 PM
