Choke Cap Question
Old Jan 26, 2014 | 10:05 AM
LARIAT 85's Avatar
LARIAT 85
Choke Cap Question
I recently bought this electric assist choke cap but it didn't come with any instructions. But it did come with TWO gaskets. My Autolite 4100 with the thermostatic choke cap only used the upper gasket. Can someone tell me if both gaskets are used and what is the purpose of the lower gasket?
Old Jan 26, 2014 | 10:18 AM
fmc400's Avatar
fmc400
MSEE
Only use one or the other. The cut-outs in the lower one are for the tang as well as hot air in and out to the "cavity" that gets created between the gasket and the choke spring itself. The lower gasket may help distribute warm air over the choke spring more, I'm guessing. I've seen it on a lot of 2150s and it always seems to be included in kits. If your original used the circular gasket, just use that. On 2150's, the two small holes line up with the ports in the choke housing - if that's not the case on the 4100, then definitely don't use it.
lalberts
15
Dec 24, 2017 06:56 AM
dustyroad
Mar 24, 2015 12:43 PM
fmc400
55
Jul 30, 2014 10:11 AM
LARIAT 85
Jan 26, 2014 03:53 PM
Myfreeford
Apr 15, 2013 10:03 PM
