Bad choke gasket?
Old Mar 29, 2013 | 05:59 PM
Myfreeford's Avatar
Myfreeford
Bad choke gasket?
I hooked up a "smoke machine" (home made with a jar, two rubber hoses and a smoking object in the jar. One hose connected to the center tube on the front of the carb and I blew gently thru the other end) and found smoke coming out of the round gasket of the choke adjustment. I learned that at some point, I did not put the tension clips back on when I had reinstalled it. As a result, the choke turns freely when the bolts are tightened. But, before I realized the clips were missing, I did the smoke test.
Would this "leak" be a source of a vacuum leak when the engine is under a load?
Just to confirm, there is a small hole/opening at the bottom front corner of the choke area. while smoke also came out of there, that is not the area that I am concerned about. I am referring to the gasket where the black round choke adjustment mounts to.
Old Mar 30, 2013 | 12:27 AM
wdfp's Avatar
wdfp
Yes it would be a vacuum leak, clean air is drawn thru the choke to cool the spring inside on many electric or electric assisted carbs and its drawn thru by vacuum from the engine. Probably wouldn't notice much under load, unless it whistled or something like that,but would affect it more at idle plus sucking unfiltered air into your engine.. I can't think of what opening you might be speaking of though..
Old Apr 9, 2013 | 10:16 PM
fmc400's Avatar
fmc400
MSEE
Air is drawn through to heat the choke thermostat after passing through an exhaust crossover. The choke has to get hot to open.
To the OP - I couldn't really follow what you're saying.
Refer to this thread on how the hot-air choke is supposed to work:
https://www.ford-trucks.com/forums/8...-answered.html
Old Apr 13, 2013 | 01:18 AM
wdfp's Avatar
wdfp
Some have nothing going thru them like Demon carbs too
Old Apr 13, 2013 | 10:10 AM
fmc400's Avatar
fmc400
MSEE
I'm not sure what that means.
Old Apr 15, 2013 | 12:18 AM
wdfp's Avatar
wdfp
Demon carbs with electric choke have no air moving thru them at all, not to cool the spring or to heat it, which seems kind of odd but that is how they are built. Holley and Edelbrock both pull air thru them to cool the spring which is what I was talking about earlier. I know the stock ones with heat stove are the opposite but they don't use a full 12 volts thru the choke either.
I read your article on chokes quite a while ago, and liked it. I thought it was good information and well explained also. It just didn't occur to me that he may have been talking about a stock choke set up with the heat tube and all. That happens to me sometimes though, I try to read everything twice before saying anything but even that doesn't help sometimes..
Old Apr 15, 2013 | 10:03 PM
fmc400's Avatar
fmc400
MSEE
Thanks for the clarification; I understand now.
fmc400
55
Jul 30, 2014 10:11 AM
1986F150six
Jan 18, 2013 06:03 PM
hotrod351
Mar 26, 2010 06:26 PM
Jeff3298
Sep 6, 2008 10:19 PM
59INA40
Nov 8, 2006 03:55 PM
