Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Brakes
Old Jan 25, 2014 | 11:53 PM
jmtbiggin's Avatar
jmtbiggin
Question Brakes
In the process of getting the 61 f500 going again.Got my widowmaker(rh5) problem solved. Now for the other widow maker. Have any of you converted your single resevior brake master to a dual resevior and made a split system?Thanks
Old Jan 26, 2014 | 08:21 AM
tinman52's Avatar
tinman52
Welder User
Does your truck have a Hydrovac? (vacuum booster)
Old Jan 26, 2014 | 10:15 PM
jmtbiggin's Avatar
jmtbiggin
Yes under the drivers side of cab
Old Feb 1, 2014 | 01:55 AM
cj06's Avatar
cj06
Switch the hydrovac out for a hydroboost system from a mid - late 80s school bus !
Old Feb 7, 2014 | 07:47 PM
Mariekelleher's Avatar
Mariekelleher
FDS75 Front Axle
I have a Ford with a six stud FDS75 front axle and I want to convert it to ten stud. Is this possible?
Old Feb 13, 2014 | 10:21 PM
fivestarmmd's Avatar
fivestarmmd
Dont what is involved but I have a 80? F600 that was converted from 6 bolt to 10 bolt. I know it was 6 bolt when recabed it in 93 for po. front and rear are 10 bolt stud pilot. Only got for spare 8.2 detroit in case needed for 83 F800 I have.
Old Feb 14, 2014 | 03:52 PM
Mariekelleher
FDS75 ten stud
Re FDS75 ten stud front hubs - can you tell me if it is hydraulic brakes and what size? We could be interested in buying the whole front end or just the hub section to convert ours if it is for sale but I do not need the diff centre. Our ratio is 6.83.
Thanks,
Scruffy.
Old Feb 26, 2014 | 06:59 PM
pweng1's Avatar
pweng1
hydrovac to hydro boost
Can you explain whats needed and what involved in the swap from hydro vac to hydroboost
Old Mar 27, 2014 | 06:29 AM
pweng1's Avatar
pweng1
Tinman you put the vacuum on your build. I have a chance to buy a 90 f450 hydro boost with mater cyl. for my running coe that i want to mount underneath do you know if ill be able to bolt it up and is it a good idea?
martyanderson10
Large Truck
Apr 19, 2015 08:48 PM
itslow
Large Truck
Jul 16, 2013 03:31 PM
jimluw
Large Truck
Jul 5, 2011 12:53 AM
66F100Again
Mar 9, 2007 03:36 AM
spencer5148
Aug 27, 2004 05:00 PM
