Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
C-Series Master Cylinders
Old Apr 30, 2013 | 08:05 PM
itslow's Avatar
itslow
Was the C-series every updated to use dual circuit master cylinders during its production run? If so, when did it happen and what was changed (ie; mounting brackets, pedals, vacuum booster, etc)?
What would be the part number for the master cylinders? Single and/or dual. Rebuild kit part numbers?
I think y'all can figure where I'm going with this inquiry...
Old May 1, 2013 | 02:33 PM
85e150's Avatar
85e150
The master attached directly to the pedal feeds a hydrovac** power assist device mounted on the frame of the truck. Making a dual system out of this would entail re-engineering the brakes and a different booster.
Interesting info regarding the C brakes here--good luck with it:
https://www.ford-trucks.com/forums/1...h-systems.html
Last edited by 85e150; May 1, 2013 at 10:34 PM. Reason: correct "hydroboost" to "hydrovac".
Old May 1, 2013 | 05:35 PM
dmanlyr's Avatar
dmanlyr
I have several brochures for the mid eighties C series, and yes, they do have a dual circuit hydraulic braking circuit.
They also list disk front brakes as part of this brake setup.
As to other changes, I have can't help you there, as I have yet to find a later C series to inspect in person that was not equipped with air brakes.
David
Old May 1, 2013 | 09:29 PM
itslow's Avatar
itslow
Yeah, that's a thread I started shortly after we got the truck.
I'm aware of how the single circuit system would work, but given the improved safety of a dual circuit system, I was wondering if the C-series were ever re-engineered to use them. I've seen master cylinders listed on eBay for the C600 that are dual circuit, but the accuracy of such types of auctions are frequently seem to be incorrect and use generic information.
It's also interesting to hear that they were also switched over to use disks in the front.
dmanlyr, what years in the 80's are your brochures from?
I wonder how adaptable or interchangeable the later parts are with the earlier trucks with some minimal work (ie; bracket fabrication). Anyone know if they'd be the same as or similar to those used on the F-series counterparts?
Old May 1, 2013 | 09:45 PM
dmanlyr's Avatar
dmanlyr
1985 and 1987. I should probably scan them and post them as I have done some others.
It was interesting to find out about the disk brakes to me as well. I was actually trying to find out if Ford ever put integral power steering on these trucks, and lacking later model parts or service manuals, I bought a few later brochures to look at.
Sometimes you have to be careful with people, they tend to try and shorten things up or not properly research what they are selling. A good example is in the case of the 80's C6000, C7000 and C8000's. I cannot count the times when people have stuff listed on ebay as fitting these trucks, when in truth they are for the CF6000, CF7000 and CF8000's which are totally different trucks other than the blue oval. Yes, one letter or one numeral can make a difference!
Even Napa has confused these two distinctly different series of trucks.
David
Old May 1, 2013 | 10:35 PM
85e150's Avatar
85e150
Originally Posted by itslow
Yeah, that's a thread I started shortly after we got the truck. ...............................
Wow, I may need a minder with observation skills like that......
Old May 1, 2013 | 11:10 PM
dmanlyr's Avatar
dmanlyr
I scanned the 85 brochure but gig not post it right as I only wanted the links, not the pictures to show up directly.
I also scanned a interesting circa 85 Ford C series verses the Imports "hotline" report.
It and other C series, as well as some limited older F series and soon to be HT series stuff can be found on my photobucket account - same user name of "dmanlyr"
David
Old May 1, 2013 | 11:11 PM
dmanlyr's Avatar
dmanlyr
Happens with age - in my case sometimes I review old posts, and am surprised at what I posted years ago!
David
Old Jul 16, 2013 | 03:31 PM
itslow's Avatar
itslow
Ok. Another question that probably doesn't have an easy answer short of dismantling the master cylinders on the truck.
What are the bore sizes on both the brake and clutch master cylinders?
jhaas63
Feb 16, 2018 06:24 AM
prndl
1961 - 1963 F100 Unibody
Dec 27, 2012 06:14 PM
midcal48
Apr 7, 2011 09:43 PM
ksmith203
Mar 15, 2007 09:42 PM
wiskey63
Aug 1, 2002 09:14 PM
