Shop computer Diag worth it?
Old Jun 28, 2003 | 12:50 AM
welbo97's Avatar
welbo97
Hello,
I replaced my original plugs with Bosch 1p's at 88,000 miles. By 88,500 the truck was missing intermittantly. I've started moving to the Bosch +4P's. I've put two in so far (time constraints) #1 and #7 and swapped the coils too. Now it's missing to the point that the engine won't idle and stalls right after startup and gives a check engine light with idle underspeed error. I hate to replace the rest of those plugs if it's going to get any worse. Is it worth it to get a shop to hook up to it and tell me their opinion? All I have is a code scanner. I can't tell for sure which cylinders are missing.
'97 5.4L Expd'n EB 4x4
Thanks,
Old Jun 28, 2003 | 05:56 PM
Rtpjunior's Avatar
Rtpjunior
Go to a Pep Boys, or similar, for an oil change, and have them read your codes. It will only cost you an oil change. I have used the bosch plugs you speak of, but pulled them after only 1000 miles because they really sucked. I bought a set of the OEM motorcraft plugs, and it runs fine..............
Old Jun 28, 2003 | 06:07 PM
BigMattXXL's Avatar
BigMattXXL
I, too, have heard that the Bosch +4's aren't too great. Racerguy is a ford tech, and he only recommends the OEM Motorcraft Double Platinum plugs.
XXL
Old Jun 28, 2003 | 10:30 PM
welbo97's Avatar
welbo97
Thanks for the replies. I believe I'll just get the motorcraft plugs and cut my losses.
Another question if you will... RtpJunior, you mentioned getting my codes scanned. I have a code scanner and all it's ever returned is an idle underspeed error. Would it return a code indicating which cylinder was missing under any certain circumstances? Just wondering if there is a clue there I'm missing. It's a '97 model, in case there is a difference in later model computers.
Thanks
Old Jun 29, 2003 | 10:18 AM
Rtpjunior's Avatar
Rtpjunior
Yes, if you get a particular cylinder that misfires, you will get a specific code for it. I have a 97' as well, and whenever one of my coils would crap out, I would get codes from 0301-0308. Each one represents a particular cylinder misfire (0301 for cylinder 1, and so on...). I do not know which scanner you have, but mine (Actron) will display the code # on screen, as well as its definition. It would be highly unlikely to have all 8 cylinders misfire at once, but if they did, the code you are getting may be right. You idle speed is set by the ECM, and not user adjustable. That being said, something is causing the motor to idle incorrectly, possibly the plugs. Expy's are picky on spark plugs, and the OEM motorcrafts are very high quality for a factory part. I know the logic you are following : better plugs=better spark=better combustion=more mpg & HP. This is true for most vehicles, but most do not use the coil-on-plug system, as our trucks do. I have tried the Bosch plugs you used on other vehicles (non-expys) with very good results. I hate to say this, because I know the labor involved, but I think a switch back to the OEM plugs will solve your problem...
Old Jun 29, 2003 | 10:31 AM
welbo97's Avatar
welbo97
I agree with you now, Rptjunior. That's exactly why I posted here. I wanted to know if I should continue replacing plugs with the Bosch or go back to the motorcraft. This should save me a lot of labor. These are about the hardest plugs to replace I've ever done. It takes some of the craziest combinations of u-joints and wobble joints and extensions I've ever seen! Even the COP is hard to get off on some cylinders.
You nailed the logic I was hoping for. My mileage had been slipping and I thought I'd get it back up with a set of spark plugs. Maybe I'll browse the other forums and see if there are any good suggestions for increasing mileage with upgrades.
Thanks a lot for the help. It was exactly what I was looking for!
Old Jun 29, 2003 | 10:41 AM
Rtpjunior's Avatar
Rtpjunior
You are very welcome. As for MPG upgrades, keep your tire pressure constant, get a good wheel alignment, and try not to drag race from a stop. I have a problem with that because I love the sound of my Flowmaster....................
Old Jun 29, 2003 | 04:26 PM
welbo97's Avatar
welbo97
Okay, one last question, I hope... I went to the auto parts store and asked about their selection of Motorcraft plugs for the Expy. They had what they called Fine Wire. It is a tiny electrode with one ground bar. I've heard Motorcraft Double Platinum suggested as the only plug to use. Is this the same thing? I thought double platinum would mean it has two electrodes or two grounding bars (like the bosch 2+ does).
Thanks again
Old Jun 29, 2003 | 08:29 PM
bbeever's Avatar
bbeever
which way are you turning the new spark plugs?
Old Jun 30, 2003 | 05:25 AM
Rtpjunior's Avatar
Rtpjunior
I think the "double platinum" OEM plugs refers to a 2X coating of platinum at the tip. If memory serves, when I did mine, the plugs had a single tapered electrode, and 1 ground bar. I would just ask for the OEM's, part # AWSF22E.
Old Jun 30, 2003 | 09:33 PM
welbo97's Avatar
welbo97
So I installed the FoMoCo double platinums and it runs a lot smoother. But it still stalls after starting when hot. And it generates a MIL with a manufacturer specific code of P1507, Idle Underspeed Error. Anyone know how the idle speed is controlled on these engines? I'm going to read the maint. manual cd and try to get some insight. Shortcuts to the answer are always appreciated!
Old Jul 1, 2003 | 05:20 AM
Rtpjunior's Avatar
Rtpjunior
I am sure you reset the ECM after the new plugs were installed. I believe the motor is set to idle at 750 rpm, and to the best of my knowledge, is NOT user adjustable. There is, however, a screw on the throttle body that looks like you can adjust, opening the throttle is small increments. Give that a try.....
Old Jul 1, 2003 | 05:22 AM
Rtpjunior's Avatar
Rtpjunior
I forgot, it is on the left side of the TB, where the throttle cable attaches to a spring loaded metal plate. The plate rotates when you open the throttle, and the screw I speak of contacts it on the very top......
Old Aug 29, 2004 | 10:54 AM
Quick_Rod's Avatar
Quick_Rod
Would bad gas also cause this situation?
I recently went on vacation and stopped to fill up at a cheap filling station. I then experienced this same problem (same code) with the exception of bad idle on cold starts not hot as someone else mentioned. On my return trip home I selected BP for gas, the light continued to stay on until I cleared it but the stalling never returned.
So far I have not had a re-occurance (knocking on wood).
Matt957
1997 - 2003 F150
Mar 27, 2017 12:44 PM
Lady J
Mar 21, 2016 11:33 AM
Joeyd99
Modular V10 (6.8l)
20
Dec 30, 2015 05:43 PM
areyou4real
Aerostar
26
Nov 9, 2015 05:19 PM
seattle smitty
15
Aug 27, 2015 10:37 AM
