V-10 Misfire on #4 cylinder
I recently purchased a 2002 Ford F250 SD with the famous/infamous V10. The truck was owned by a woman who used it to pull her horse trailer on occasion, the truck is in great shape with a tad over 161K. The truck was running fine when I got it, the only problems were a shudder in OD and an exhaust leak. I was aware of these problems and the price was adjusted accordingly. I had all of the manifold bolts replaced at a local muffler shop, which took care of the exhaust leak. The next step was to have the plugs changed and the transmission serviced, I also had the air/fuel filters changed along with the EGR valve. I had a local shop do this for me, using Napa parts and Bosch Iridium plugs. I picked up the truck last Thursday and it was smooth as butter, ran better than when I took it up there and the transmission shifted like a new one with zero shudder in OD, but it didn't last long. I drove it a short way, turned it off for a few minutes then when I started it back up, I noticed a miss, not a bad one and barely noticeable. It doesn't miss at idle, only after I put it in drive. Took it back to the shop and put a code reader on it, came up with a misfire on #4 cylinder. The shop manager, whom I've know for years, said it was a COP. He had the delivery guy bring a new one from Napa, installed it, but it was still had the small miss. I wasn't in a hurry to get the truck back and he was pretty covered up, so they didn't get a chance to look at it until today. I just got off of the phone with him and he said something about the code not resetting and it might need to be driven for a while before it would reset. I really don't think that is the problem, I believe it is one of the aftermarket boots that were installed. Any ideas? Suggestions? I may be wrong, but I am inclined to believe that the miss is the result of something that was installed, in that there was no miss when I took it up there. The spark plugs that were removed were burnt pretty bad, I'm not sure if they had ever been replaced. Any help/suggestions would be greatly appreciated!
Still there? Swap #4 COP with another one that's easy to access.
Still there? swap #4 injector "" "".
Still there, investigate base engine (compression, etc).
Thanks for the quick reply. Dang, could have sworn that I read somewhere that the Bosch plugs were a good alternate to the Motorcraft. But looking at the old plugs that came out of it, they were burnt pretty bad and the truck wasn't missing. I guess I should have left the plugs/boots alone, it wasn't missing. Live an learn I guess. Thanks for the info, I will pass it along to my mechanic.
Well, that turned out to be a lot easier that I was expecting. A set of Motorcraft plugs and a new COP on #4 cylinder and the truck runs great. Actually, I am amazed at how good it runs. When I bought the truck it wasn't 100%, had an exhaust leak and the dreaded shudder in OD, now it is as smooth as butter and I am a happy camper! Thanks a lot for the great advice! My mechanic didn't say it but I know he was skeptical about changing the plugs, but it worked. Again, thanks for the info!!
That has been my experience. I didn't see the why in it either, so I tried not replacing the plug when I replaced the coil. It still had the miss, and the miss went away when I replaced the plug. I remember asking this question when I was in the throes of my COP problems. I never cured my chronic COP problems until I fixed my ground issue.
Well, thanks for the heads up on the corrosion issues. They use a lot of salt on the roads in the winter around here, so I will need to keep an eye on the cables and such. I'm a little hesitant to brag on how well the truck runs now, afraid that I might jinx myself But, dang, it is running really good! Thanks for all of the replies!
I just bought a 99 250 v10 116k
literally 1 mile out of the hole pooped a plug. private sale seller rigged it to sell it.prior to that it seemed smooth
fast forward $400 something later shop did the heli coil like repair 1 plug and coil. It still has a sort of stumble with little load at low rpm
I changed all 10 plugs myself and its still there (motorcraft plugs)
I would have had shop do it but they wanted $1000!!!!
I was looking at some aftermarket COP set ups for like $60 for all 10
Am I wasting my money on them? I figure A shop would get
me $100 just to look at it so it could be a good gamble if a coil is a coil
Have any of you ever used global automotive parts ? E BAY
any suggestions? is there a way i can figure out my issue?
^^^^ While I appreciate trying to save a buck or two keep away from eBay COP's unless they're Motorcraft. Sure they're more money but from personal experience there's nothing advantageous about cheap COP's. I use NAPA's better brand and pay only $50 each---considering I'm driving a van with a few OEM original COP's with over 275K miles I'd say the better brands make a lot of sense.
If your engine has a misfire due ignition issues the CEL should be lit up---if so get the codes read and share them with us.
As a side note its better to start your own thread rather than tacking another issue onto an existing one---too often it gets lost and the situation never really addressed.
