Pulled the spindle nut off... Now what?
Old Jan 25, 2014 | 10:08 AM
patdm's Avatar
patdm
Hello folks. Never really post anything here because of such great information, but now I have a question.
78 F150 4x4 rotor and bearing relacement
Everything came off without a hitch until I got to the spindle nut. It was loose. I just reached in and spun it off by hand. Strange. No clicks either, but I can see the perforated washer is in place. Now the real problem. The rotor is not loose. Am I missing something on this older truck that is not present on the later models?
Any input is greatly appreciated.
Oh, and a pic for fun
Old Jan 25, 2014 | 10:30 AM
dlburch's Avatar
dlburch
remove the washer and the nut behind it...then things should start getting loose...
Old Jan 25, 2014 | 10:32 AM
USArmyTaterness's Avatar
USArmyTaterness
also could have a bit of rust in there so once you get those off a few light raps with a soft face (if your saving it) or a decent mallet if your not.
Old Jan 25, 2014 | 10:33 AM
cammok5's Avatar
cammok5
did you take the washer out and then take the second nut off?
jason77F250's Avatar
jason77F250
I dig those wheels man. As far as your issue, try a couple wacks with a rubber mallet.
Old Jan 25, 2014 | 10:43 AM
patdm's Avatar
patdm
Thanks k5, I just figured that out. The washer is loose but kinda stuck in the threads. If I can get it out, I should be on my way
Wheels are AR Baja if I remember correctly
Old Jan 25, 2014 | 10:46 AM
patdm's Avatar
patdm
Thanks to you too dlburch. Sorry i missed your post. I'm on my phone and for some reason not all the posts were showing up.
Old Jan 25, 2014 | 02:15 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Nice truck, I like the color scheme, green on the inside too?
You sound like you got it figured out, here is $.02
1. Go to any local parts place and get a 12.00 Chilton or Haynes manual.
2. Buy a 6 or 8 dollar 4 point hub socket......no hammer required.
Old Jan 25, 2014 | 03:27 PM
turbohunter's Avatar
turbohunter
I would add, get yourself some curve tip probes. It's much easy to grab/dislodge stuff with them. At least one 90 degree sharp tip.
BTW sweet truck.
Old Jan 25, 2014 | 04:28 PM
tbear853's Avatar
tbear853
Nice Truck .... glad you got the other nut off.
Old Jan 25, 2014 | 04:30 PM
-mywheels-'s Avatar
-mywheels-
Beautiful truck! Love the colors and wheels.
Old Jan 25, 2014 | 08:24 PM
cammok5's Avatar
cammok5
use a pick set or small screw driver to walk the washer off.
in case you didn't notice the second nut has a little nipple on it that goes into one of the holes in the washer. when you put it back together that nut has to go in 1st with the nipple facing out then the wash then the outer nut.
Old Jan 25, 2014 | 09:41 PM
Scoop531's Avatar
Scoop531
Beautiful truck
Old Jan 27, 2014 | 04:44 PM
patdm's Avatar
patdm
Thanks for the tips and compliments. She's in good shape now. Just waiting on some parts from broncograveyard.
Pics and a pinion socket I have. Don't have a manual. Apparently my memory is gone too. Been longer than I want to admit since I've worked on one of these.
mikeinri
23
Oct 27, 2020 09:20 PM
BLDTruth
Jul 16, 2017 03:50 PM
deezel
2004 - 2008 F150
Mar 31, 2014 06:53 PM
ReFlectiveMan
Feb 18, 2012 11:04 PM
Darth_Stroker
19
Aug 23, 2006 07:38 PM
