Motor condition
Old Jun 27, 2003 | 11:02 PM
albertafarmer's Avatar
albertafarmer
Question Motor condition
I just bought a F-150 parts truck with a 460 engine. Whats the best way of asertaining motor condition with out taking it completely apart.
I want to put the engine in a F-350, don't want to get it installed and find out it's a completely wrecked.
Old Jun 27, 2003 | 11:04 PM
Mil1ion's Avatar
Mil1ion
Motor condition
Start it up and look for Blue smoke.
Do a compression test.
Take the valve covers off and check the valve seals
Look for Oil leaks.
Old Jun 27, 2003 | 11:33 PM
albertafarmer
Motor condition
I can't start the engine where it is, too many parts missing. I am going to do a compression test.
Would the starter turn it fast enough to check the oil pressure?
Old Jun 28, 2003 | 12:14 AM
i_alone's Avatar
i_alone
Motor condition
where abouts in AB?, as for the oil pressure, I not too sure about it spinning fast enough to properly register
Old Jun 28, 2003 | 11:31 AM
stuperscout's Avatar
stuperscout
Motor condition
The starter will not get it for oil pressure. without it warmed up oil pressure is only relative not accurate
Old Jun 28, 2003 | 06:43 PM
albertafarmer
Thumbs up Motor condition
Thanks for the advice , I think I may be able to start it, I'll have to jury rig some wiring, and some sort of fuel line.
Whats the bare minimum of wire needed just to start it, can I run a wire from plus battery post to + side of coil?
Well a good way to spend a Sunday afternoon.
Old Jun 28, 2003 | 06:55 PM
Mil1ion's Avatar
Mil1ion
Motor condition
yes, but don't run it too long or you will burn out a factory coil.
If you havea coil that normally runs on 12v that would be great.
If you can crank it at least 15 revs you should get at least 10 psi
oil pressure actuated switches operate at a slightly lower pressure reading.
jwcopeland
18
Jan 26, 2017 03:44 PM
sand1
Ford Truck Parts for Sale
Jun 20, 2016 12:29 PM
CMHII
May 27, 2016 10:27 PM
SSgt82-02
May 18, 2015 01:27 PM
1975 f150 360
Oct 17, 2003 12:35 PM
