460 won't start
Old Jun 28, 2003 | 03:20 PM
trolly79f150's Avatar
trolly79f150
Angry 460 won't start
I just finished getting my 460 into my 78 F150 Supercab... and the darn thing won't start. It turns over real hard, the battery connectors and wires get red hot, it belches white smoke thru the carb... what is wrong? I know its something with the timing, but what? The timing marks, piston, and distributer rotor all line up where they should at TDC, Any ideas? Could i be 180 degrees off? Anything will be helpful.. thanks
Old Jun 28, 2003 | 04:56 PM
LxMan1's Avatar
LxMan1
460 won't start
It is possible. Remove the #1 plug(the front on the passenger side), Put your finger over the hole, bump the starter over until the compression blows your finger off of the hole, line up your timing mark at 0. Check and see where the rotor is pointing. If it is at #1 plug wire, it may be wires in the wrong direction.
Jimmy
Old Jun 28, 2003 | 11:05 PM
Dartagnan00001's Avatar
Dartagnan00001
460 won't start
Remembre that the distributor turns counter clockwise when you check your firing order
