Exhaust Cleaning duration
Old Jan 24, 2014 | 07:18 AM
96sherm's Avatar
96sherm
Hey all,
I've been enjoying my 6.7 for 2700 kms now, and have a question about the "Cleaning Exhaust Filter" cycle. I drive 27 km/16.5 miles too and from the city where most of my work is, the message "Cleaning Exhaust Filter" comes up about 1/2 way during the trip. Its happened 4-5 times in the 2700kms. I'm assuming this is normal, but wondered how long does this cycle last? I've never gotten a message that the clean is complete, or to continue driving so it can finish... It sure does get smelly from the heat!!
Thanks for your insight.
Old Jan 24, 2014 | 08:13 AM
2ndStroke's Avatar
2ndStroke
Sounds about right, you can watch your instant mpg going down while it goes through the regen the only way to tell it's done is when it goes back up, usually 10-15 mins and the cycle should be over if I remember correctly
Old Jan 24, 2014 | 08:35 AM
Randy_270's Avatar
Randy_270
The more stop and go driving and the more idling you do the more often your truck will regen. On the highway should should be regening about every 800-900km(ish). It takes about 15 minutes for it to complete but the truck has to be up to I believe 65C but I'm not 100% sure on the temperature.
Old Jan 24, 2014 | 08:42 AM
2ndStroke's Avatar
2ndStroke
Oh, I also only got the "drive to clean message" once or twice in the first year.
Haven't seen any messages in 1.5 years now
Old Jan 24, 2014 | 08:47 AM
Irelands child's Avatar
Irelands child
Mine seldom goes though the cleaning cycle - especially since I finally figured out that if you are in 'Tow' mode shown on the in-dash screen, it happens a lot more often.
Old Jan 24, 2014 | 10:35 AM
don.joyce59's Avatar
don.joyce59
I have found that short drives will cause mine to regen very frequent. I don't think it ever gets the filter clean before I shut it off so it will not go far before it does it again. When I am towing it does it very infrequently.
Old Jan 24, 2014 | 03:20 PM
FordDOsq's Avatar
FordDOsq
Hi!
Mine does that cleaning also around that 900km circles. Now its pretty cold weather (-20 C) and i´ve had to idle more than usual and last time (some days ago) it started on my way to home and couldnt finish it. So today it tried again to clean it on my way home and i drove over 15-20km extra (+15mins) and still didnt end it. Will see how next trip goes.
It wouldnt shift gear to the end while burning.. and consumption went up to 16 L/100km.. grr had it down to 12L/100km after highway/mixed road (1 hr go)
Im ready to change that DPF delete kit (watched some video and saw its replaced with straight pipe including that sensor- so no big deal to make it own) as we dont have any emission rules for that if im correct... need to check it. (in Finland)...
And im not looking any HP increase or so, only reasonable going without that stupid fuel burner bowl. It looked pretty simple thing to (re-)replace even if u have under warranty vehicle.
Old Jan 24, 2014 | 08:32 PM
kper05's Avatar
kper05
I can't imagine why.
Old Jan 24, 2014 | 08:52 PM
Tofan's Avatar
Tofan
Funny you ask about this, mine started on the way home the other day. I had some liquid in the bed of my truck and when i parked my truck, you could hear the DPF burning off whatever liquid was pouring down onto the exhaust. I was like man, I would hate to have to touch that! It will soon be gone though
Old Jan 24, 2014 | 10:33 PM
kper05's Avatar
kper05
At 1,150°F or hotter, you simply couldn't touch it for more than an instant.
This is what the exhaust did to a sheet of paper.
Even with gloves I couldn't hold my hands there for more than a few seconds.
Old Jan 25, 2014 | 08:19 AM
96sherm's Avatar
96sherm
Thank you for all your replies. Sounds like everything is normal. Interesting what the exhaust did to the paper. I parked really close to a snowbank the other day and melted a pretty good hole in it.
Old Jan 25, 2014 | 08:50 AM
miker73's Avatar
miker73
Along the se line of question,
My 2010 6.4 F350 not only has the exhaust cleaning light
But also a large amount of smoke from the
Exhaust as well. So much so the cars behind
Me drop way back.
Local dealer said its normal ?
Old Jan 25, 2014 | 12:01 PM
kper05's Avatar
kper05
Me drop way back.
You might want to ask the 6.4L guys or look through the topics in there.
I've heard quite a few stores where the 6.4L trucks billow smoke during a regeneration, which could be related to moisture somewhere it shouldn't be.
No one that I can remember has reported this issue with the 6.7L.
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
https://www.ford-trucks.com/forums/1...ing-regen.html
Old Jan 25, 2014 | 05:29 PM
Traveling Man's Avatar
Traveling Man
Your motor will regen based on the soot build up in the exhaust filter. Every truck will build up soot differently based on the type of fuel, driving habits, and load on the engine. No two trucks will clean the exhaust the same but based on my experience, if you are light on the throttle with no load you will regen more.
Old Jan 26, 2014 | 07:44 AM
96sherm's Avatar
96sherm
I understand this, but it seems backwards to what it should be. You would think that light/conservative driving would create less soot, and pouring the fuel to it while towing would create more. I guess its the exhaust temps that help burn off the soot when you're towing and driving hard.
