Battery maintainer
Old Jan 23, 2014 | 12:20 PM
Country Traveler's Avatar
Country Traveler
Battery maintainer
I don't use my '05 with V10 much in the winter. Can a battery maintainer be wired permanently to the battery or does it need to be disconnected when the truck is running.
If it can be, does it get too hot under the hood to mount it there?
Thanks.
Old Jan 23, 2014 | 01:22 PM
ExploringNH's Avatar
ExploringNH
It will be fine under there. A lot of them come designed to mount under the hood with a short plug to stick out of the grille like a block heater.
I use a Battery Tender on my motorcycle and it has it's own quick disconnect plug. This leaves the tender at home and available to use on other batteries or vehicles. The plug end stays on the bike and other stuff can plug into it when the tender isn't being used. I'm sure that plenty of other manufacturers have the same or similar setup.
You can see the plug here:
Old Jan 23, 2014 | 02:01 PM
Country Traveler
Thank you. I did a little google searching after posting but nothing as clear as your post.
Old Jan 23, 2014 | 02:15 PM
Tedster9's Avatar
Tedster9
That's a handy dingus too. On the Ranger at least, the battery location is such you don't even have to open the hood to hook up.
Old Jan 23, 2014 | 03:06 PM
EXv10's Avatar
EXv10
I just charge the battery every 2-3 months.
Old Jan 23, 2014 | 03:12 PM
Gene Horr's Avatar
Gene Horr
That's the standard setup on boats and RVs. As soon as you start the generator or hook up to shore power the charger/maintainer automatically receives power and is kept wired up at all time. Just make sure that it is the automatic type unless it is a trickle charger.
Old Jan 23, 2014 | 04:03 PM
robert_l_ross's Avatar
robert_l_ross
I wouldn't mount the actual control box under the hood (on the one you posted the pic of, anyway). That one in the pic comes with leads that connect to the battery terminal bolts and then have a 2 prong connector similar to a trailer disconnect.
From the manual:
IMPORTANT SAFETY INSTRUCTIONS
"2) Do not expose charger to rain or snow" = NOT waterproof
"5) An extension cord should not be used unless absolutely necessary."
CHARGER LOCATION
"a) Locate charger as far away from battery as dc cables permit"
Personally, I'd run the leads provided from the battery to a convenient location (grille, wheel well, etc.). I'd then either buy the 12.5 ft or 25 ft extension from the company or even just make an extension (those quick-disconnects are easy to find at most auto parts stores or you can make your own using Anderson Power Poles) that would run from your truck side connector into your garage (under the garage door, etc.) where you'd then connect it to the actual battery tender.
They do make waterproof ones designed to be mounted on motorcycles, snowmobiles, etc. that are waterproof that you could mount under the hood with no worries.
Old Jan 23, 2014 | 04:43 PM
EXv10's Avatar
EXv10
That's why I just charge my sitting batteries every 2-3 months.
Old Jan 23, 2014 | 06:25 PM
robert_l_ross
I only run this since the battery it charges (a 1000cca boat anchor) is for us to use during emergency deployments to power radios, winch, etc. It's nice to just have it ready to go with no worries like "oh, I was going to charge that this weekend but now I have to use it".
But then again for certain things I have OCD and that would keep me up at night, lol.
Old Jan 23, 2014 | 07:34 PM
Larry Grimes's Avatar
Larry Grimes
trickel charger
You got make shure the charger you buy has a diode that prevents backfeed from battery to charger wants you unplug the 110 volt..there is a parsitik load.
Old Jan 23, 2014 | 10:10 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i have a 1.5A trickle charger mounted behind my bumper and hooked permanently to the battery. when i go on vacation and its not being driven every day i plug it in keeps it in tip top shape.
Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps
Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps : Amazon.com : Automotive Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps : Amazon.com : Automotive
Old Jan 24, 2014 | 01:33 AM
Tedster9's Avatar
Tedster9
Modern vehicles tend to have a low level drain on the battery built right in, because of all the electronics - the clock for one thing, passive alarm system, and golly knows what else, sometimes takes up to a half hour after shutdown to settle down. It's not much, but it doesn't help. I'd bet this contributes to a shorter battery life? And don't disconnect the battery, because depending on the make and model can require a trip to the dealer.!
Can't make this stuff up.
Old Jan 24, 2014 | 06:27 AM
Country Traveler
Looks like the winner. Thanks for the info and link.
Old Jan 24, 2014 | 06:32 AM
Country Traveler
Exactly. My truck has a high end radio (for the day 2005) and the Viper alarm also adds to the drain. After about 2 weeks, it is done. I have to go to a Viper dealer with both keys to re-program the remote start function. Needless to say, right now the battery is in my garage because it went dead due to the unusually cold weather here in NY.
Old Jan 24, 2014 | 06:33 AM
Country Traveler
You are lucky if you can go 2-3 months. If I could, I would not have this problem.
