Steering noise
Had this on my 93. One of the rivets that hold the spindle assembly to the frame had popped out. I realigned the holes with a tapered drift and replaced the rivet with a 5/8 grade 8 bolt and tightened that sucker as much as I could. It could also just be the coil spring shifting in its seat.
dg
on
1 Post
"My 96 eclb had a popping when turning.it had one of the rivets that held the engine xmember to the frame rail.it was one of the big ones at the corners.I may have welded the frame to the xmember lol...it fixed it at least"
I will check that, I was thinking about it yesterday and wondered if it is at the steering box and the knocking is being transmitted thru the frame, making it sound like it is hitting the floor.
It is getting worse, started out just occasional noise, now it is all the time. I have got to find this problem before something falls off that shouldnt. Maybe I can crawl under it this weekend and give it a good exam, if it will warm up that is. My garage is mother nature so I am at her mercy.
on
1 Post
Anafiel
16
12-17-2010 12:25 AM
