Mirror Replacement
Old Jan 23, 2014 | 08:59 AM
BrassMonkey's Avatar
BrassMonkey
Mirror Replacement
Hi guys,
Just have a question. I'm looking to switch out my regular mirrors for tow mirrors. I have found a used set nearby that came off a 2009 f150. They are heated, power, and have the signals, same as what I currently have. So what I was wondering is, if anyone knows for sure if the '09 mirrors will fit on my '13. If any one has any idea let me know.
Old Jan 23, 2014 | 10:00 AM
Trailblazen's Avatar
Trailblazen
I know that 09-12 fit my 2009. I want to say that the 13 they changed the posts but not 100%. I could be wrong. I know when I put tow mirrors on I had someone mention something like that to me. I did the install myself and it wasn't too hard.
Here is my thread for the mirrors I got. I can't find/remember where I heard the compatability issue but its sticking out in my head from a prior conversation:
https://www.ford-trucks.com/forums/1...lind-spot.html
Old Jan 25, 2014 | 11:50 AM
BrassMonkey
thanks for the reply, also, can anyone tell me what the easiest way to remove the stock mirrors is. Do I need to remove the whole door panel?
Old Jan 25, 2014 | 01:11 PM
KJ Smith's Avatar
KJ Smith
Remove the door panel.
It's easy, there is a 5/16 in the door handle under the cover.
Two 1/4 on the bottom edge.
Door panel lifts straight up. No prying.
On the '13 there are three studs, two on bottom, one on top.
The wiring is a modular plug.
Old Jan 26, 2014 | 01:07 AM
Trailblazen
Yes the Door panel has to be removed. Thats why I linked my thread cause I had a small little writeup with some tips from when I did mine on page 2 post 21. If its like my 2009 don't forget there is one under the panel in the little storage area on the arm rest. I actually found a youtube video for the door panel removal and used that to guide me through removal and reinstall. use my string technique too for making sure the plugs don't get trapped in the door.
Killer RC
24
May 13, 2015 05:24 PM
tozir
2004 - 2008 F150
Jun 21, 2011 01:31 PM
My2000F250SD
Electrical Systems/Wiring
Dec 4, 2006 07:39 PM
lovemy150's
Oct 19, 2006 09:42 PM
Toored
Jul 18, 2006 08:26 AM
