tailgate assist
Old Jan 23, 2014 | 07:53 AM
derek4343's Avatar
derek4343
tailgate assist
has anyone installed a deezee tailgate assist with any luck? i tried installing but the factory hole seems too big for the nutset. mine is oblonged. let me know
Old Jan 23, 2014 | 08:12 AM
Robbgt's Avatar
Robbgt
See Rob's post here https://www.ford-trucks.com/forums/1...l#post13376265
Old Jan 23, 2014 | 08:52 AM
04XLTRUNNER's Avatar
04XLTRUNNER
Mine went on just fine. Works just like its supposed to.
Old Jan 23, 2014 | 09:01 AM
BrassMonkey's Avatar
BrassMonkey
I'm looking into buying one of these, and after reading other posts I am just going to skip the nutsert, and use a washer, lock washer and nut on the inside instead. Little bit more work to get a nut in there but it seems like the general consensus is that is works better than a nutsert.
Old Jan 23, 2014 | 09:04 AM
billybobzia's Avatar
billybobzia
I had no problem with it.. went on quickly and easily.. I would suggest looking at the online video first, it clarifies the process in my opinion, the written directions are a little vague
Old Jan 23, 2014 | 09:16 AM
SabreFX4's Avatar
SabreFX4
Make sure you have the right one for your year of truck...there was a change in the mounting between the 09 and 11 pickups that I had.
Old Jan 23, 2014 | 11:44 AM
pepito113's Avatar
pepito113
I just ordered one. The only question I have is if that shock should be holding weight? In a video I saw the tail gate cable didn't seem stretched all the way. Maybe The other side was holding it. Not sure. Can anyone confirm if the cables are lose or tight? If they are loose then its safe to say the shock is holding some thee weight of the door...
Old Jan 23, 2014 | 11:47 AM
SabreFX4's Avatar
SabreFX4
The cables hold all the weight on mine.
Old Jan 23, 2014 | 11:56 AM
ruff rider's Avatar
ruff rider
On my 13 Platinum the cables are both at full length when down just as if I didn't have the tailgate assist. I have to say I love the system. I also agree with the above statement about watching the video on installation. It made it much easier for me to understand how to install.
Old Jan 23, 2014 | 02:33 PM
PrinceValium's Avatar
PrinceValium
Thanks for the plug Robb...lol
Mine went in without issue using the supplied equipment. You just have to be careful not to go too far with the tightening or it can damage the tailgate. It is a great little quick addition to the truck that really does help!
Old Jan 23, 2014 | 02:49 PM
Turbo Dog's Avatar
Turbo Dog
I've got one on my 2013 and it works great...seems kind of odd to not use much torque on that mount, but it hasn't come loose. I do like it and I installed it because we sleep in the back of the truck sometimes. It makes letting the tailgate down from the inside of the bed much nicer.
Old Jan 23, 2014 | 03:21 PM
MCDavis's Avatar
MCDavis
I purchased one last week.
Instead of the nutsert I'll be using a 10mm nylock nut and a 1" stainless fender washer that I've glued together. If you remove the tailgate panel you can screw the ball end directly into the glued nut/washer.
Found that fix here:
EZ Down nutsert problem SOLVED!! - FORD RAPTOR FORUM - Ford SVT Raptor Forums - Ford Raptor
Old Jan 23, 2014 | 06:22 PM
derek4343's Avatar
derek4343
thanks to all...i got it. i never marked it and i did have to do it three times to get it to bite. works great
alchemist1
Jun 20, 2015 06:14 PM
dukie1877
Feb 2, 2012 08:09 PM
Jaime74656
Sep 3, 2011 05:45 PM
bit_bucket
6.7L Power Stroke Diesel
Aug 10, 2011 12:46 PM
blanes
Jan 14, 2008 09:07 AM
