General Automotive Discussion
97 explorer question
Old Jan 23, 2014 | 06:18 AM
slaterkey's Avatar
slaterkey
what is the lever above the ignition barrel? it doesn't seam to have a purpose.
also... how can i fix my ignition barrel? my key is pretty worn and i can start my truck without my key... and even when i use my key... i can take the key out while truck is running. i dont like this one bit.... how can i fix it? do i have to replace the key and barrel?
Old Jan 23, 2014 | 07:12 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, you have to replace the key and barrel. I replaced mine recently. A new one was about $25 at my neighborhood parts store.
Old Jan 24, 2014 | 02:00 AM
slaterkey's Avatar
slaterkey
but what is the small lever?
Old Jan 24, 2014 | 07:41 AM
Mark Kovalsky
That lever allows you to turn the key to LOCK. Without pressing the lever you should only be able to turn it to OFF, not lock, and not remove the key. It is only on manual trans vehicles, automatics do that with the shift handle. You can only turn an automatic to LOCK and remove the key when it is in park.
banshee_man_96
Nov 22, 2018 07:20 AM
joestanf
Dec 21, 2017 03:36 AM
metriccar
Nov 20, 2013 07:44 AM
1988-Ranger
1983 - 2012 Ranger & B-Series
Jun 7, 2004 08:00 PM
K2JJB
Jun 4, 2004 09:22 PM
