Sponsored by: Auxito
frame rust
Old Jan 22, 2014 | 07:08 PM
sowder's Avatar
sowder
frame rust
I have a 51 F6 and the frame is good, also a 79 Bronco frame is good, my 98 Expedition frame is fine. Today I jacked up my 98 F150 for tie rod work, placed my stands under the frame, let the jack down and the stand go's half way through the frame on the passenger side. Any good way to fix this so it's safe? or is it junk? no way I would sell this like it is. anyone else run into this?
Old Jan 22, 2014 | 09:08 PM
steve(ill)'s Avatar
steve(ill)
You need to clean up the frame and inspect to see the total damage. If this is an isolated area, i think you could plate over it. If there is 2-3 foot long area that is bad, then the frame is shot. Older frames were thicker and heavy. New frames are thinner and higher alloy steel to get the same strength. Wire brush and black paint/ undercoating will help these trucks a lot in the midwest salt winters.
bbsitum
1997 - 2003 F150
25
Oct 11, 2025 02:45 PM
tbenks
Offroad & 4x4
21
Feb 17, 2010 11:44 PM
78ford351m
Jun 28, 2006 06:11 PM
IowaTower
Paint & Bodywork
Jan 25, 2006 11:07 PM
1ole4d
Apr 15, 2005 11:34 PM
