Fuel leak
Old Jan 22, 2014 | 04:22 PM
77mud's Avatar
77mud
Fuel leak
Saturday I had a fuel leak line coming outta the Filter setup on the engine that loops around and looks to go into the head behind/under the AC Compressor. It had evidently split before because it was already spliced together so for the time being i cut the split out and re spliced it.
what is the proper name of this hose so I can pick up a new one to fix it properly instead of the rigging that it is now. Thanks for any help
Old Jan 22, 2014 | 06:28 PM
fordman67's Avatar
fordman67
Fuel regulator return hose
Old Jan 22, 2014 | 06:51 PM
77mud's Avatar
77mud
Thanks! Hopfully it is easy and cheap to locate
Old Jan 22, 2014 | 06:55 PM
fordman67's Avatar
fordman67
Riffraff..or ford.or a hydraullics shop might build one
Old Jan 22, 2014 | 08:23 PM
Leemakesmepee's Avatar
Leemakesmepee
If youre replacing the one side, you might as well do the other side.
Old Jan 23, 2014 | 03:42 PM
77mud's Avatar
77mud
Yea i had no luck with auto part stores. Anyone got a idea what threads are in the head?
Old Jan 23, 2014 | 09:25 PM
Leemakesmepee
Do you have a napa around you? Thats where i got mine made. Also maybe try a hydraulics shop.
Old Jan 24, 2014 | 03:40 PM
77mud's Avatar
77mud
We have a napa but i refuse to use it. The employees are dumber than advance an the rest of the name stores. Worst part is its family owned an operated an still that bad.
Old Jan 24, 2014 | 05:12 PM
ReBilld's Avatar
ReBilld
The threads in the heads are 1/8" pipe thread, but a new hose will go right on the fitting that is in there already. They are #4 JIC
Old Jan 24, 2014 | 06:28 PM
77mud's Avatar
77mud
Were it was spliced used a barb. I was thinking bout switching the piece in head to a barb.
Old Jan 25, 2014 | 07:12 AM
ReBilld's Avatar
ReBilld
I would leave it JIC and get new hoses.
f350xlt460
Feb 19, 2023 08:41 AM
snakedoc
Aug 17, 2011 10:30 PM
matt7293
Dec 14, 2010 07:02 AM
Mustangfreak
Apr 6, 2010 03:58 AM
sidala
Oct 18, 2004 01:17 AM
