Fuel leak
Old Dec 14, 2010 | 06:32 AM
matt7293's Avatar
matt7293
Fuel leak
"My ford f350 is leaking fuel from under my truck, their is no hose or line connected to it. Is this a return line or some kind of overflow line how do I fix this problem."
Old Dec 14, 2010 | 06:34 AM
matt7293's Avatar
matt7293
Old Dec 14, 2010 | 06:51 AM
Copedawg's Avatar
Copedawg
WELCOME TO FTE!!! mat7293!
If you are finding fuel under your truck it is most likely leaking fom on top in "The Valley". When we develope leaks it collects in the valley and runs down the back right (passenger) side of the engine. There are a few things up there that can leak, fuel pump, banjo bolt or a few lines, the bowl it's self. What you have to do is remove the "Darth Vader Mask" and clean it up real good. I would focus tat the fuel pump. There are 2 weepholes that will leak when your pump is spent.
Let us know what else you need
Old Dec 14, 2010 | 07:02 AM
Copedawg's Avatar
Copedawg
Here is a good write up on a fuel leak w/pics: https://www.ford-trucks.com/forums/8...-write-up.html
Here are some other good links to put on file
This is the most important link: 1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Tips - Idea - Hints
97-15A 7.3L DI Turbo Workshop Manual
1996 Bronco/F-Series Workshop Manual
