F-150 Light Issues
Old Jan 22, 2014 | 01:17 PM
jconner's Avatar
jconner
F-150 Light Issues
Today's the day for Ford lights to act up. I replaced the multi-function switch the other day and now I can't keep a fuse good for the brake lights. I've pulled the wheel off and looked for pinched wires and such. No sign of issues, taken apart the plug and inspected, no visible issues. ??? There's the brake light switch high on the brake pedal and another switch lower on the pedal closer to the floor, any idea what the lower connector is for??? I'm on the verge of using a metal clothes hanger instead of fuse then replace the melted wire!!!!! Any ideas??
Old Jan 22, 2014 | 01:40 PM
Franklin2's Avatar
Franklin2
See if there is a big plug at the bottom of the steering column that disconnects all the column wiring. If there is, unplug it, then see if the fuse blows. If it doesn't the problem is in the column.
Old Jan 23, 2014 | 10:25 AM
jconner's Avatar
jconner
thanxs dave for the quick response. I found the wildest, after pulling the steering wheel and making sure no shorts/pinched wires, I replaced the fuse. brake lights good, as soon as I put the steering wheel back, "pac", the fuse blew. I must be grounding ??? w/the wheel in place and not w/it off??
Old Jan 23, 2014 | 05:50 PM
Franklin2's Avatar
Franklin2
Makes sense. See if there is any black marks on the wheel. If not, then replace the fuse and then start pushing on different things like the wheel would, to see if you can find the problem.
Old Jan 24, 2014 | 07:19 AM
jconner's Avatar
jconner
gotta love them ol' fords!! more digging to follow, i'll update when located, thanks for the thoughts,,,,,,,& prayers!!
Expo007
Apr 22, 2014 11:59 AM
fireftrcjo
Sep 22, 2009 01:06 PM
mark a.
Electrical Systems/Wiring
Oct 10, 2006 09:00 PM
Adam L
May 23, 2005 06:39 PM
TallPaul
Jul 31, 2001 10:25 AM
