U-joints?
Old Jan 21, 2014 | 01:34 PM
Jamie Arceneaux's Avatar
Jamie Arceneaux
U-joints?
When I am coming to a stop in my E99 I hear a loud clunk under the truck. It can be felt by both myself and the passenger and it happens every time I slow down to a stop. Would this likely be U-joints? If so how to I check them to be sure? If not what else should I check?
Old Jan 21, 2014 | 01:52 PM
clem1226's Avatar
clem1226
Of you have a spare tire under the bed make sure it isn't flat.
Old Jan 21, 2014 | 03:07 PM
snakedoc's Avatar
snakedoc
where under the truck is it?
might be the slip joint, brake parts.
Old Jan 21, 2014 | 03:14 PM
Jamie Arceneaux
it feels like it is directly under the front seats.
Old Jan 21, 2014 | 03:28 PM
Tim Hodgson's Avatar
Tim Hodgson
Do you have a two-piece drive line with a slip yoke in the middle? (My van should have had that, but instead it has the dang slip yoke on the transfer case tail piece which is a known leak problem.) On the Bronco, the slip yoke between the two-piece driveline was often the source of that mysterious clunk. No need to disassemble the ujoints, just grease the slip yoke splines.
Old Jan 21, 2014 | 03:31 PM
Jamie Arceneaux
yes it is the 2 piece. It has three U-joints
Old Jan 21, 2014 | 03:58 PM
tdpower's Avatar
tdpower
Could be the ball joints. Mine did that when breaking hard and would clunk. I never fixed it though because I got rid of the truck. You might want to check your front sway bar for play as well.
Old Jan 21, 2014 | 11:13 PM
dieselandmud's Avatar
dieselandmud
Check the leaf spring bushings.
rangerbait
6.7L Power Stroke Diesel
Jul 26, 2020 09:56 AM
ShawnQ
Nov 16, 2014 10:05 PM
itsafordguy20
2004 - 2008 F150
Feb 1, 2011 03:59 PM
phil350
Aug 23, 2004 10:13 PM
el conquistador
1983 - 2012 Ranger & B-Series
20
Jul 3, 2004 02:02 PM
