X Engine Noise
Not quite right. Rereading the OP's original post, that is exactly what the OP is suggesting, fearing, or wondering about. The rest of us are hoping to avoid even the remotest possibility of the same misfortune with our own trucks when it comes time for service. So we are "crowd concluding" that we really don't need to subject our transmissions to "box of chocolates" flushing services, where you never really know what your going to get.
Here's a highlighted look at the original post:
Anyway, I drove it home and the noise was significant, but more importantly, it was a noise I had never heard up to this point.
Logic prevents us from assuming that the fluid in the flush machine would break apart a flywheel. Even the OP wondered if it was some type of exhaust leak instead. But the point is, his Ex didn't make the noise before he brought it in for service, and then suddenly did make the noise after he picked it up. That is our worst nightmare. That is why the B.A.R. was invented. That is what makes us want to think about ways to avoid being exposed to that type of risk, whether it was an innocent mistake, ignorant blunder, or well practiced trick to turn a $300 nibble into a $3,000 nugget to pay the shop rent. Whatever the original service guys did or didn't do, that was a very expensive transmission flush.
It has been done before and documented even on tv. A transmission would be a fairly fast change out. But a flywheel wouldn't be worth the trouble. At the same time if the shop was playing around and "checking stuff' because of the new noise I would be worried what they did to try and fix 'cover up' the problem.
called her Dad and he visited the shop. they ended up refunding all the money for the supposed "repairs" they did. He is also 300 lbs and over 6ft. A bit intimidating when angry I've been told
long story, but I would be tempted to believe the OP was "had" by the repair shop. It's likely they didn't even do any work and just held onto the truck for a certain amount of time. Or, they may even have caused the issue and played dumb
When you do that you are just diluting the bad oil and not accomplishing much. Your trans will last longer and you will have more free time if you do it right.
For anyone wishing for a torque converter drain plug... know that it is not only not necessary, but it also won't get all the fluid out, because there will still be old fluid in the pump passages, the valve body, the oil to water cooler in the radiator, the oil to air cooler in front of the radiator, and all the lines and fluid circuits in between.
The advantage of using the transmission's own pump to push all the old fluid out via the clear vinyl tubing attached to the rear return line, is that the fluid flows one way, and the replacement fluid handily serves as a hydraulic "broom" that sweeps all the clutch debris laden fluid out of all the passages, torque converter, fluid coolers, pump, valve body, lines, everything, right into the 5 gallon bucket at your feet.
Couldn't be slicker, unless you use synthetic transmission fluid! (ha ha)
Another reason for not wanting to drill and tap your TC, and not wishing your TC had a drain, is because it is a PAIN in the DONKEY to service a transmission in this manner (draining TC). Think about it for a second... How fast does the crank spin at idle? 650 RPM? So what is the probability that you will magically shut off the engine such that this torque converter drain plug just so happens to end up bottom dead center so it will fully drain?
Not gonna happen. So now you need a Big M.F. Breaker Bar with a deep socket attached to hand crank the motor at the harmonic balancer until the drain plug on the torque converter ends up where you want it. Or you could try pulling a fuse and bump starting it. I've tried that. It takes longer than hand cranking the motor.
Scroll up a little and have one more look at the picture I posted of the factory torque converter drain plugs. Notice the remaining text imprinted the Ford bag. That's the FINE PRINT on the bag. Does that offer a better idea of just how tiny these little drain plugs are? They are the smallest drain plugs I can recall working with on a vehicle.
Now, picture how small that hole is on the Torque converter. Visualize how long it will take to gravity drain the entire contents of the torque converter through this tiny hole, that is, IF you are able to successfully align the hole to the bottom dead center (and think about the time that took). I'm not speaking in theory. I have DONE it this way. That baggie in my picture is of the three remaining drain plugs that I did not use, because I decided many years ago never to do it this way again.
In case you're wondering, it takes about a DAY for the torque converter to finally stop dripping oil steadily, once the draining process begins. So for those going through this effort to get "every last drop of old oil", best have another vehicle to use while your waiting. By contrast, the built in transmission pump pushes fluid out at a rate of over 1.2 gallons per minute. All day? Or 5 minutes? Hmmmm.
These are just a few more reasons for not lamenting the loss of a torque converter drain plug.
You really shouldn't be giving false info in here
I fully expected this, as the many vanes and fins inside the TC make for a lot of surface area. It takes time for the the oil to gradually sheet down each vane, drip to the next interfering vane in the path of gravity from it to the drain hole, and repeat. Surface tension slows the process more.
Obviously, in a time sensitive service bay, the bulk of the oil wold be drained, and then the plug put back in. But that creates another issue, because now the efficacy of the thread locker is compromised by the remaining oil that keeps dripping out of the TC after the bulk drain.
So no matter how much time one allows for the TC to drain, even a mere 30 minutes, there are still downsides to the process. The purpose of my posts were to point out these downsides so that Excursion owners can be reassured that they are not missing anything. There are easier and more efficient ways to change ALL of the transmission fluid without draining the TC, and without going to a flush machine.
Since the majority of Excursion owners with the 4R100 do not have the TC drain plug, due to the Excursion being introduced in 2000, and the TC drain plug being deleted within a year thereafter, these points of view might be useful to some.
It's a free country. You do it your way, I do it mine. My Town Cars don't have TC drain plugs starting 2003 and I refuse to flush the transmissions. My fluid will be burnt at 50k miles from heavy city driving with hills. There are people that change their engine oil religiously at 3000 mile but look at you like you just landed from Mars when you ask them how often they service the transmission.
1. It is another unnecessary point of failure... ie, not torqued correctly, no use of loctite, wrong use of loctite, not replaced with new plug that has built in loctite, replaced with new plug of wrong size, stripped by careless lube jock, over tightened by careless lube jock, forgotten by careless lube jock (lube jocks are often the lowest paid, least trained techs in the service bay)
2. It is another unnecessary cost in production. All of the fluid in the transmission can be exchanged without removing the torque converter drain plug, without removing the sump drain plug, and without using a flushing machine of any kind. You can even do it without a friend. In your own driveway. It just goes a little faster with someone else helping. Could be a spouse, or even a child. Or just Father Time.
The flushing machine pumps the fluid, but the transmission already has a pump. So why not use it? Attaching a clear vinyl tube to the fluid return line at the rear of the transmission, routing that clear tube to a 5 gallon pail by the driver's door, and staging about 16 pre opened quarts of fresh fluid near the dipstick with a funnel in it, turns your Excursion into it's own flushing machine. Start the key, let it run till a couple of quarts flow out, then have your friend steadily add more in. Or stop the engine, pour a couple in, restart, let a couple pour out. Repeat.
The new fluid pushes the old fluid out. Eventually, the color of the old fluid being pushed out of the clear hose will change into the same color as the new fluid being poured in. Keeping track of what has been pushed out and what has been poured in will keep the fill level reasonably close to what it was when you started.
Draining the bottom of the pan first is good, dropping the pan to check the magnet is good, even changing the filter in the sump is good, but not really required as often as the fluid itself should be changed. But draining the torque converter? Completely unnecessary using the self pumping procedure briefly described here, and fully described in Mark Kovalsky's write up that he first posted about 12 years ago, when the TC drain plug was deleted.
Strongly do not recommend drilling and tapping a TC. The extremes of heat the TC is subjected to would very quickly compromise that white seal seen in that Dorman drain plug pic posted above. That would be a very unforgiving mistake. The damage would happen astonishingly quick from a fluid loss at that point. Don't do it.
There are a few types of flushing machines. One uses its own pressure to "push" the fluid through. Places like Jiffy... use these machines, with the car off, and they cause way more harm than good. Never do that.
The other kind of machine uses the cars transmission pump to "pull" fluid from what they call a bladder, a thing full of clean fluid. This is what you want to use.
Then there's the heated vs not heated flush. The 5R110 will not allow cold fluid to flush through.
Trying to find a heated flush bladder type machine is nearly impossible, hence why I now just drain what'll come out, then do it again a few months later.
