X Engine Noise
Dorman® AutoGrade™ 65241 - Universal Transmission Drain Plug Kit | O'Reilly Auto Parts
Basically you drill a big hole in the pan (the right size hole for the kit). The kit comes with a through bolt with a hole in the middle, a washer, a nut for the other side, and the through bolt has a drain in it.
Its a bit nerve racking drilling a hole in a perfectly good pan. The biggest thing to watch for is clearance inside the pan so your new drain plug doesn't interfere with the trans internals. I spent a lot of time measuring the depth of the pan, how much all the trans parts stick down, and looking for a spot where it would fit. The drill the hole, install the plug, get everything nice a snug and you're done. I've read not to use any sealant as that can get into the trans fluid. Also, when you next go to drain the fluid, hold the the assembly itself with one wrench and turn the drain with another, that way you don't risk loosening the whole thing up. If you do, you'll have to drop the pan and tighten it again.
I used this one:
Hope that helps.
PS
PS AFAIK this only works with steel stamped pans.
. Tap, I don't think the converter wall is thick enough. You might get one or two threads. Not enough to hold. But wouldn't that be nice!I don't think my 5R110 torqshift has any way to drain the converter or even see it from under the car.
Its weird how some your transmissions have the plug and others don't. I'm not sure what Ford's reasoning was for removing it at some point.
Mark Kovlowski posted the how to long ago here somewhere. I did it and didn't spill a drop. Trans has been shifting and acting the best its ever been at 170K!
1. It is another unnecessary point of failure... ie, not torqued correctly, no use of loctite, wrong use of loctite, not replaced with new plug that has built in loctite, replaced with new plug of wrong size, stripped by careless lube jock, over tightened by careless lube jock, forgotten by careless lube jock (lube jocks are often the lowest paid, least trained techs in the service bay)
2. It is another unnecessary cost in production. All of the fluid in the transmission can be exchanged without removing the torque converter drain plug, without removing the sump drain plug, and without using a flushing machine of any kind. You can even do it without a friend. In your own driveway. It just goes a little faster with someone else helping. Could be a spouse, or even a child. Or just Father Time.
The flushing machine pumps the fluid, but the transmission already has a pump. So why not use it? Attaching a clear vinyl tube to the fluid return line at the rear of the transmission, routing that clear tube to a 5 gallon pail by the driver's door, and staging about 16 pre opened quarts of fresh fluid near the dipstick with a funnel in it, turns your Excursion into it's own flushing machine. Start the key, let it run till a couple of quarts flow out, then have your friend steadily add more in. Or stop the engine, pour a couple in, restart, let a couple pour out. Repeat.
The new fluid pushes the old fluid out. Eventually, the color of the old fluid being pushed out of the clear hose will change into the same color as the new fluid being poured in. Keeping track of what has been pushed out and what has been poured in will keep the fill level reasonably close to what it was when you started.
Draining the bottom of the pan first is good, dropping the pan to check the magnet is good, even changing the filter in the sump is good, but not really required as often as the fluid itself should be changed. But draining the torque converter? Completely unnecessary using the self pumping procedure briefly described here, and fully described in Mark Kovalsky's write up that he first posted about 12 years ago, when the TC drain plug was deleted.
Strongly do not recommend drilling and tapping a TC. The extremes of heat the TC is subjected to would very quickly compromise that white seal seen in that Dorman drain plug pic posted above. That would be a very unforgiving mistake. The damage would happen astonishingly quick from a fluid loss at that point. Don't do it.
