jan 03 build 6.0 help
Old 01-20-2014, 09:53 AM
grainmaker181's Avatar
grainmaker181
grainmaker181 is offline
Any guys with early 03 built engines have any advice for me. I have looked for hours through old posts as to what to do with the dreaded egr. My engine has 80,000 miles on it and I am looking at doing something with the egr before it goes bad.
what is the best way
1. Unplug egr valve
2. block off plate
3. egr delete kit (which one do you like)
4. after market egr cooler fix (ie bulletproof egr cooler)
I never plan on retuning for higher hp which I think expedites egr problems, looking for longevity of engine. I also live in rural nebraska so i doubt we will have any sort of emissions testing any time soon.
Old 01-20-2014, 11:37 AM
npccpartsman's Avatar
npccpartsman
npccpartsman is offline
I like the IPR delete and up-pipe. It's a bit more expensive but way less, IMHO, likely to wiggle loose and leak. The replacement up-pipe is much better quality also. I'm sure there are cheaper but I like quality if I can afford it. If you haven't done the exhaust then Magnaflow or MBRP are excellent quality and good price if you shop. You'll need stainless. 3.5" downpipe to 4" back is GREAT for a stock truck. No mods or tuner needed either. Leave the EGR valve in place and hooked up electrically since it's moot anyway but the circuit needs to be connected.
Old 01-20-2014, 12:38 PM
Unrealo4's Avatar
Unrealo4
Unrealo4 is offline
Your 03 has the beefier egr cooler. My truck has a 03 motor also. I wouldnt even sweat the egr cooler in that truck.
Old 01-20-2014, 01:12 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
I Agree on the 03 Cooler^^^
But it does recycle Lots of Junk back into the engine and soots the sensors etc..... SO my vote is get rid of it
DO you know what shape the oil cooler os In???
Old 01-20-2014, 10:11 PM
grainmaker181
I dont know for sure what shape the oil cooler is in. Im looking at getting a scanguageII so i can check the operating oil temps. If i had to guess I would say the oil cooler is in good shape. I am the third owner of this engine, its in an excursion that the original owner loved but wife made him trade in at 16k miles cause it was to big and made the garage smell. 2nd owner also took care of vehicle as far as i could tell he had it from 16k-75k. Regular oil changes with full synthetic, hot shots additive. So I don't know for sure but it appears to have been taken care of and kind of babied. Neither did any towing or hp mods either.
Old 01-22-2014, 08:34 AM
grainmaker181
what egr delete do you have
6.0 diethel
11-21-2010 11:50 AM
lakewood
12-15-2009 07:20 PM
036liter
09-07-2009 09:45 AM
cartmanea
04-05-2008 09:11 AM
"Luke" SdeS
02-15-2004 03:22 PM
Quick Reply: jan 03 build 6.0 help
