Wiring problems
Old Jan 19, 2014 | 05:43 PM
lowcountryF100's Avatar
lowcountryF100
Wiring problems
Well before I started the only problem was the running light on the left rear with the headlights on of course. Now I have all the turn signal blinking when I put the left signal on. The right performs as it is suppose to. 2.5 hours and I am no closer to the problem maybe farther. 1970 F100 shortbed
Old Jan 19, 2014 | 08:24 PM
Ben-jamin's Avatar
Ben-jamin
this is very typical to a ground problem. your signal power is hunting through the sockets until it finds ground. I suggest pulling the signal bulbs and checking ground continuity from the socket to frame.
Old Jan 20, 2014 | 12:21 PM
JEFFFAFA's Avatar
JEFFFAFA
If you were re-doing dash or T/S wiring just before your l/s signal started messing up, double check yourself. A lot of PO's *******ize the dash wiring and make it hard to follow. If this is the case,Ya might consider re-doing your wiring the KISS method. Keep It Simple Stupid. (not meant to be personal)
Old Jan 20, 2014 | 02:39 PM
Freightrain's Avatar
Freightrain
Is the blinker actually blinking the bright element in the bulb? Or is it just blinking the running lights on the other bulbs? Know what I mean? If it is back feeding into the parking lamps, it could then blink all the other bulbs. Remove the lenses and confirm.
Don't know about your previous issue, but sounds like something is crossed up.
Old Jan 20, 2014 | 08:36 PM
Gembone's Avatar
Gembone
I had a similar issue and it was from bad grounds and a bulb installed improperly. Be sure to double check everything.
jinxit
Aug 26, 2016 05:36 PM
Tony238
13
Apr 24, 2007 08:28 PM
lucky no. 7
Sep 25, 2006 09:19 PM
rmalottwtes30
Dec 6, 2004 12:11 PM
pigfanatic
Aug 27, 2002 12:01 PM
