Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Brake Booster Lubrication
Old Jan 19, 2014 | 07:24 AM
m350's Avatar
m350
Hey all, Just Installed a rebuilt Brake Booster(frame mount) on my 83' F-700, and the Instructions say to "Lubricate the Booster" with the Specified oil and amount, But did not see any info on it or where to add it to the Booster ?
Anyone that has some info on this would be helpful, thanks,,Mark
Old Jan 20, 2014 | 03:16 PM
85e150's Avatar
85e150
What oil and what amount did they specifiy?
I find a couple references for older hydrovacs with leather seals.
Oil in Hydrovac - Binder Planet Forums
How Do You Lubricate a Hydrovac?
There are pics in those links showing the oil fill hole, you gotta dig a bit but they are there.
Old Jan 24, 2014 | 06:04 PM
m350's Avatar
m350
Thanks for the info, after reading more about them, some have the fill ports, some don't(mine does not have the plug) As I read the info the Boosters that need the oil (older units)have leather cup/diaphragm in them that need to stay supple.
Newer units have no plugs, need no lubricant for there rubber cup/diaphragm .
I can see rubber where the Booster bolts together but don't know if any leather is in side.
The info/direction sheet that came with the Booster showed separating the lower vacuum hose and squirting the 1-2 oz of oil in towards the Large Diaphragm, but did not specify what brand or type of oil to use., Mark
GoldCo
Mar 22, 2018 12:10 PM
cabloom300
Oct 10, 2009 02:21 PM
Boanerges
Feb 27, 2009 01:11 PM
dagray3
Dec 20, 2008 07:11 AM
