56 trans ID
Old Jan 18, 2014 | 05:30 PM
skotyg's Avatar
skotyg
56 trans ID
Hi guys,
I took my 3 speed trans out of a 56 f100 to be cleaned and and have new bearings and seals put in. I got parts from NPD for a light duty ford trans with no overdrive and the parts aren't correct. Are there any markings or anything to ID the trans so I can get the correct parts? Thanks for any help!
Scott
Old Jan 18, 2014 | 06:51 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Can you show some pictures of the trans?
Old Jan 18, 2014 | 07:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Got this out of his gallery. It looks big for a light duty?
Old Jan 18, 2014 | 07:26 PM
skotyg's Avatar
skotyg
Ah, it could be a heavy duty? I apologize, I forgot to add that there pics in my album. Thanks for looking!
Old Jan 18, 2014 | 07:41 PM
hiball3985's Avatar
hiball3985
That looks just like the two light duties I have in the garage. Did you possibly get parts for a passenger car 3 spd?
Old Jan 18, 2014 | 07:49 PM
skotyg's Avatar
skotyg
No, it was for the truck. Is there anywhere else that might have parts I can double check?
Old Jan 18, 2014 | 09:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What is the casting number on the trans case?
What parts didn't fit?
Old Jan 18, 2014 | 09:41 PM
skotyg's Avatar
skotyg
Hi
I'm not sure what the casting number is and I think he said one of the bearings wouldn't fit and one did fit. (the bearings I ordered for front and rear were the same). Can I tell from the casting number? I can get it if I need to.
Thanks!
Old Jan 18, 2014 | 10:04 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yes, the case number will help. The Parts CD shows that in 56 the Medium duty trans was also a "remote control" (column shift) trans.
You are much better off dealing with VanPelt Sales for tranny stuff, but you absolutely need the trans ID'd by at least case number first. www.vanpeltsales.com
There should be a number on the bearings that can be matched too.
Old Jan 18, 2014 | 10:41 PM
skotyg's Avatar
skotyg
Thanks Ross
I'll check that out!
Old Jan 19, 2014 | 08:20 AM
38 coupe's Avatar
38 coupe
The light duty transmissions were side loaded Ford transmissions. The 1956 medium duty transmission is also side loaded, a Borg-Warner T89. That transmission is top loaded. You have the heavy duty 3 speed, a Borg-Warner T87.
Old Jan 19, 2014 | 08:54 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The clutch linkage anchor appears to be on the side plate? Look at the BH bolt pattern too, longer dimension is vertical. The drain also. I think it's a side-loader.
Old Jan 19, 2014 | 09:37 AM
hiball3985's Avatar
hiball3985
It's a side loader sitting on it's side, thats the drain plug on the bottom, not a fill plug, the fill plug is on the side it's resting on.
Old Jan 19, 2014 | 11:40 AM
38 coupe's Avatar
38 coupe
Opps, I feel embarrassed. You're both correct, it is a side loader. Ford transmission then.
Old Jan 19, 2014 | 01:24 PM
skotyg's Avatar
skotyg
Yes it is a side load. Just have it on its side
matthewq4b
Aug 10, 2016 07:53 AM
cstempert
Ford Truck Parts for Sale
Aug 9, 2016 03:31 PM
1oldtimer
Jul 11, 2010 08:24 AM
That_Guy
22
Dec 28, 2007 06:45 AM
Franklin2
Apr 25, 2001 09:30 PM
