Valve Adjustment?
Old Jan 18, 2014 | 02:22 PM
rwrogers's Avatar
rwrogers
Valve Adjustment?
I have a 79 351W.
Just bought the truck and tinkering with it. Had a clatter, so while tuning up the engine, I thought, well why not adjust the valves...
Popped the right side valve cover off, very clean to my surprise, reached down to the first valve spring and its loose as @#@$. So ok, I go to tighten it down, but its cranked all the way down, no more room to go.
You can see a video here
1966 F100
The video is #31.
Any idea of what is wrong? Wrong push rods? Lifters not right? Etc?
I would appreciate any help that you can give.
Thanks,
Richard
Old Jan 18, 2014 | 03:06 PM
rwrogers's Avatar
rwrogers
I don't have a caliper cable of true measurement but I just measured one of the push rods using my tape measure, and its right at 8.125.
From what I see online, the stock rods should be 8.150, not sure how much difference that makes, if that's the issue, or if its something else.
Richard
Old Jan 18, 2014 | 03:25 PM
rwrogers's Avatar
rwrogers
I have verified my block is a 79.
However the heads, I'm not sure of. The spark plug uses the 13/16 socket, the head has 351 under the valve cover, and it has stud rockers.
Any help on identifying the heads would be appreciated.
Thanks,
Richard
Old Jan 19, 2014 | 01:45 PM
daveengelson's Avatar
daveengelson
Not an authority but if already have not done so, I would probably start at the effected cylinder(s) and check the clearance, if extremely loose suggest remove rocker arm and take a look at the pushrod and any damage. If able to get the engine running, suggest taking a narrow hose, or stethoscope type of apparatus and see if able to narrow search down to particular cylinder(s)? Fairly recently replaced cam and lifters as a first time 'do it myselfer' on 302 and found, in my case, adjusting rocker arm assembly required each cylinder be placed a TDC on the compression stroke, then tightened to zero lash, at which point added 1/2 turn. First attempt found zero lash does not mean one can not rotate the pushrod; rather, adjust until feel the slightest drag then add the 1/2 turn. Anyhow, it worked for me. In my case, found that after 15K miles on a rebuilt 302 the lifter seized and eventually beat the heck out of the cam lobe; needless to say, won't be giving them any more business??
Old Jan 19, 2014 | 02:02 PM
rwrogers's Avatar
rwrogers
These rockers are tightend down all the way, no more to go, yet I can still move the push rod up and down about 3/16", and I can move the rocker side to side about 1/4" There is no zero lash on these
Richard
Old Jan 19, 2014 | 02:22 PM
baddad457's Avatar
baddad457
You have positive stop rocker studs, there's no adjustment on these. Torque em down and it's done. 351W heads never had adjustable rockers from the factory.
HonestEngine302
Apr 24, 2011 03:20 PM
WATTSUP!
19
Feb 23, 2010 08:05 PM
gtuttle
Sep 15, 2009 07:22 PM
SawZall
Aug 15, 2003 10:50 AM
pl74
Feb 26, 2003 09:41 PM
